Author Topic: Pic Request: Anyone have pics of Gasser Intake on 1.6D?  (Read 6189 times)
March 27, 2012, 09:09:19 am
trav1856
  • 230
« on: March 27, 2012, 09:09:19 am »
I've got an idea of how to make it work, but I want to get some input from anyone who's already done it. (pictures help a bunch)
1981 Rabbit Diesel
1981 Cabriolet
Reply #1March 27, 2012, 09:25:51 am
Re: Pic Request: Anyone have pics of Gasser Intake on 1.6D?
« Reply #1 on: March 27, 2012, 09:25:51 am »
hang on a tic.. ive got a few.. they have BOOST lines hooked up to them, but you get the idea..
Reply #2March 27, 2012, 09:31:26 am
« Reply #2 on: March 27, 2012, 09:31:26 am »
Reply #3March 27, 2012, 09:32:48 am
« Reply #3 on: March 27, 2012, 09:32:48 am »
that fancy adapter, there where the throttle body should be, thats the KEY INGREDIENT to making everything work nice together..
Reply #4March 27, 2012, 10:09:17 am
trav1856
  • 230
« Reply #4 on: March 27, 2012, 10:09:17 am »
So basically just fab a plate for where the throttle body would go. What about the valve-cover vent? Put that into one of the ports on the intake and plug the others up?
1981 Rabbit Diesel
1981 Cabriolet
Reply #5March 27, 2012, 10:15:38 am
« Reply #5 on: March 27, 2012, 10:15:38 am »
i dont run my CCV to the intake, but if i did, i wurely wouldnt run it into one of the ports already on the intake manifold. those are all too small.. i would just drill the inlet of the adapter, thread it, and install a 1/2" npt hose barb.
or you could use a G60 intake, and feed your CCV gasses into the LARGE front port on it.. but im fairly certain that the G60 intake was the only one having that large port on the front..
Reply #6March 27, 2012, 10:20:49 am
trav1856
  • 230
« Reply #6 on: March 27, 2012, 10:20:49 am »
well on the one I have, there's a port on the passenger's side that's for some kind of sensor that looks to be 1/2 or 3/4". I was thinking of using that.
1981 Rabbit Diesel
1981 Cabriolet
Reply #7March 27, 2012, 10:28:50 am
« Reply #7 on: March 27, 2012, 10:28:50 am »
must be a mk1 rabbit intake then.. and that port should be for the cold start injector..
Reply #8March 27, 2012, 12:03:07 pm
trav1856
  • 230
« Reply #8 on: March 27, 2012, 12:03:07 pm »
Yup, that's the one. Came off of an 81 Cabriolet, same year as my rabbit. (speaking of which, I have the computer if anyone needs one)
1981 Rabbit Diesel
1981 Cabriolet
Reply #9March 27, 2012, 12:04:26 pm
« Reply #9 on: March 27, 2012, 12:04:26 pm »
81 cabby had a computer? i thought they had basic CIS..
Reply #10March 27, 2012, 06:06:36 pm
« Reply #10 on: March 27, 2012, 06:06:36 pm »
They had a basic resistance sensing control module in the rain tray.
Reply #11March 28, 2012, 03:01:14 pm
bbob203
  • 1789
« Reply #11 on: March 28, 2012, 03:01:14 pm »
whats with the dual fuel filters?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #12March 28, 2012, 03:03:10 pm
« Reply #12 on: March 28, 2012, 03:03:10 pm »
Stock filters down to something huge like 15 microns, I do believe KEvs Racor (sp?) goes down to 5 or lower? AKA Superb filtering :)
Reply #13March 28, 2012, 04:52:31 pm
« Reply #13 on: March 28, 2012, 04:52:31 pm »
http://www.vwdiesel.net/forum/index.php?topic=19458.0
Quite a few on the first page and more scattered throughout.
Reply #14March 29, 2012, 09:37:01 am
« Reply #14 on: March 29, 2012, 09:37:01 am »
2 microns Jer... so, like basically as clean as it would ever need to be..
i have 2 filters because i feel the original 15 micron just isnt enough..
the pump on my car is basically brand new, and i want to keep it that way, so with a 2 micron Racor filter, i get EVERYTHING out of the fuel, besides the fuel its self.. clean fuel leads to clean injectors, and a clean injection pump..
