Author Topic: Compression Test Results  (Read 7827 times)
Reply #15March 16, 2012, 04:22:15 am
Re: Compression Test Results
« Reply #15 on: March 16, 2012, 04:22:15 am »
I will let this comment stand as it is opinion and not abrasive in nature. This would be how one can express opinion and not be banned for rude/inappropriate comments.
I completely disagree. If I put the info up, correct/incorrect, it doesn't matter to me as it is mine to do with as I see fit.
That said, we should get back on topic, as what I have been doing is probably more distracting than deleting stuff.
To the OP, I think you are on the right track to your low compression. A rebuild maybe in order.
Reply #16March 16, 2012, 11:35:15 am
Toby
  • 728
« Reply #16 on: March 16, 2012, 11:35:15 am »
W/o the check valve in your adapter all of you readings will be lower than the real value. Also, the motor needs to be at operating temp and you need a strong battery and if possible a substantial charger on the battery between cylinders. Small differences in cranking speed + large differences in compression.
That being said, the differences high to low are troubling. Not the number of psi differenc, but as a percentage. Do a proper compression test and then you can be sure you aren't rebuilding a motor that does not really need it.
Reply #17March 21, 2012, 06:54:09 am
92EcoDiesel Jetta
Re: Deleting/editing posts
« Reply #17 on: March 21, 2012, 06:54:09 am »
Letting people delete postings does a great disservice to this board. Many threads are just about worthless because of the discontinuity. People disagree and no amount of self serving editing will change that. It also allows people to hide what may be useful information as well as mis-statements. This forum would be much better served if no posts could be edited after 12 hours, like every other board that I have ever been on. The current practice allows someone to make and absolutely incorrect post and when called on it edit his previous posts to make the people who had it right look like the lame ones. I have seen this several times on this board.
Agreed 100%. I am surprised that it was and still is allowed. Most forums have safeguards against that, e.g. editing privilege expires after a short period of time. I am surprised that person was allowed back on this forum after the damage he caused.
Reply #18March 21, 2012, 01:10:47 pm
  • 4553
« Reply #18 on: March 21, 2012, 01:10:47 pm »
I will work to limit my posts to those that do not contain any helpful information (especially with regards to any technical questions asked specifically by you) so that if I happen to edit or remove them in the future, the "damage" will be minimized.
Libbyd,  I nearly spit my mouthful of lunch on the screen laughing as I got as far as the first part of this, before the ( parens) and thought, Gee all his post from now on will lack any tidbits of information.  Then I read further.  Maybe any posts to 92Eco?
I kind of think like you in that if my post was off base then I should be removing it so as not to confuse others with the wrong information.  But is does sort of mix things up if others have countered your arguement and now those initial words are no where to be found.  Maybe just a retraction in the thread as it develops rather than pulling the plug at the base and turning the lights off.
Just a suggestion.  Now to clean the screen.
Reply #19March 21, 2012, 02:00:45 pm
« Reply #19 on: March 21, 2012, 02:00:45 pm »
this forum is really beginning to get the drama-pit feeling of the vortex..
we really need to just take a chill pill guys.. or **EDIT**whatever tickles your fancy for that matter..
were not in high school anymore guys.. dont act like were still in high school.
and further more, this is the internet.. you really need a fairly thick skin to deal with what people say on the internet.. or just not give a siht about what people think..
ZOMG! he said something mean to me on the internet! im going to go cry about it now!
doesnt that sound mature guys?
(BTW Andrew, none of this was directed AT/TOWARDS you, it was just a general statement to all users of the board)
« Last Edit: March 22, 2012, 04:59:55 am by theman53 »
Reply #20March 21, 2012, 05:59:54 pm
  • 4553
« Reply #20 on: March 21, 2012, 05:59:54 pm »
Good you qualified your statement R.O.R.  I would hate, no just not like to think that one person gets to have it all.  The **EDIT**and the chill pill combo.  You writing a prescription like that for us to pick up at the Wallys window of drive by drugs?
I would say wear the thick skin suit but not your other remedy.  We should generally give a shat about what we say.  Or write, or do for the most part in life.
Does the drama pit have a counter clockwise vortex attached to it?
« Last Edit: March 22, 2012, 05:01:00 am by theman53 »
Reply #21March 21, 2012, 06:31:23 pm
« Reply #21 on: March 21, 2012, 06:31:23 pm »
Guys, we really should leave the drug references out and get back on topic. I have no problem with what you all have posted *except stated* people have a right to their opinion even if it is wrong  ;D
Back to topic and people do need to stop trying to get peoples pistons to swell. I banned Mark, for a week, for his actions in this thread and others, if it continues I may have to lock the thread.
Reply #22March 21, 2012, 08:35:08 pm
  • 4553
« Reply #22 on: March 21, 2012, 08:35:08 pm »
So jaysen, did you retest the cylinders and come up with a different set of numbers?  Are you just re-ringing it?
Reply #23March 21, 2012, 10:58:06 pm
Baron VonZeppelin
« Reply #23 on: March 21, 2012, 10:58:06 pm »
I think all you guys are tough mean badaxx mofo's who could clean the house on both sides of Brooklyn.
Takes a man to drive an old crapbox VW Diesel 20-30 years old.
And a genius.
I'd rather talk about Jaysen's Comp Numbers being the lowest i have ever seen or read about - from a running VW Dzl engine.
Try another tool/tester on it with the engine cold and hot.
Might get better data to work with.
I drove a car with 250'ish across the board and it pushed out like a geyser when you took off valve cover cap while running warmed up. Not quite like a hot radiator cap - but in general - similar.
Even changed sound of engine.
Is yours that bad or worse ?
Reply #24March 22, 2012, 04:20:13 am
« Reply #24 on: March 22, 2012, 04:20:13 am »
But then again if someone were to write an incorrect post and be called out on it and then edit it, and afterwards delete it only to replace the lost and damaging post with a new post that is correct and helpful, but then edit this post to make it no longer helpful and someone else could look smart for correcting the new post before it was edited when actually they were wrong.  Someone could get confused and take the wrong information as correct here it stands at the vanguard of the deep fried dada movement that's where you live, that's your address ::)
Reply #25March 22, 2012, 06:26:29 pm
  • 4553
« Reply #25 on: March 22, 2012, 06:26:29 pm »
TrevOrbr,  you have been sniffing to much blow by from this engine that is so low on compression it looks like a gasser.
So are you sure of the psi jaysen?  Did you try doing the test then throw a couple of squirts of heavy oil in the top of the cylinders to see if it jumps up the numbers and by how much.  I have heard that is one method for determining poor sealing rings.
Reply #26March 22, 2012, 06:29:37 pm
« Reply #26 on: March 22, 2012, 06:29:37 pm »
The oil trick definately works, but I have been told to avoid it as oil is a fuel for diesels and could ignite in your gauge. It should always raise it a little as there is more than air to compress, but if it raises it 75 points or something more then usually it is a sign of rings.
Reply #27April 09, 2012, 12:24:08 am
Toby
  • 728
« Reply #27 on: April 09, 2012, 12:24:08 am »
OR you could avoid all of the variables and just leak the motor down. Then you would KNOW. Cheap and easy, if not quite so quick.
Reply #28April 09, 2012, 02:22:12 am
« Reply #28 on: April 09, 2012, 02:22:12 am »
195-240-220-200
Switch to gas, You'll be fine :P
As to the other topic, if you are going to call someone out for being a wrong or an idiot or whatever...quote the offending post.
Problem solved and no amount of editing on their part will ever make it go away.
Or use the ignore list.
Reply #29April 09, 2012, 05:16:08 am
92EcoDiesel Jetta
« Reply #29 on: April 09, 2012, 05:16:08 am »
195-240-220-200
good idea!
as for the op, I wonder if his low compression numbers could be due to the way he made his adapter, lowering his compression ratio.
