Author Topic: Replaced lower control arm now way out of alignment???  (Read 3927 times)
February 26, 2012, 11:46:43 am
Dirtrag2
  • 298
« on: February 26, 2012, 11:46:43 am »
Hi all,
on my 1999 mk3 jetta, today i replaced my drivers side lower control arm due to a worn bushing and when i put it all back together, the drivers side wheel is about a 1/2 turn of the steering wheel out of alignment with the passenger side wheel. ( the wheels are now pigeon toed!! )
new control arm is the same as the old one ( dimensions, angles, all the holes line up ) and everything checks out just fine on the passenger side. I am kinda stumped now and would like to figure this out, any suggestions?
thanks
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #1February 26, 2012, 12:02:56 pm
Re: Replaced lower control arm now way out of alignment???
« Reply #1 on: February 26, 2012, 12:02:56 pm »
Hi all,
thanks
ball joint bolts are egg shaped.. they allow LOTS of adjustment.. try that first.
Reply #2February 27, 2012, 04:53:09 pm
Dirtrag2
  • 298
« Reply #2 on: February 27, 2012, 04:53:09 pm »
thanks for the help ROR, but while the alignment is closer, it's not quite enough... But just enough that i should be able to back off the tie rod to make it work.
Stupid "Made in China" CRAP!  >:(
...Darcy
