Author Topic: which is better...K24 or Garret?  (Read 2334 times)
February 08, 2006, 08:44:54 pm
mpg
  • 49
« on: February 08, 2006, 08:44:54 pm »
Kind of a bland question, I know, but I just picked up 2 1.6td longblocks, each with a different turbo. Will one of these turbo's have any advantages over the other? They seem to be really close to the same size. I'm planning on doing the pump mods to accomodate up to 20psi of boost, and am wondering if I should pick one turbo over the other...
 While on the topic, I also have a k26 from a 944, and an audi 5cyl manifold/wastegate to fit. Would I be correct in assuming this turbo will have too much lag to be worth hooking up to a 1.6td? thanks
'90 Jetta AAZ T3 lifted
'81 Caddy project
'84 GLi 1.9 16V
'03 GLi 24V 6spd
Reply #1February 08, 2006, 09:09:24 pm
dubCanuck1
  • 279
    • http://www.canadubs.com
« Reply #1 on: February 08, 2006, 09:09:24 pm »
Twin 'em. Then you get the best of both worlds. 935racer's working on a Twin Turbo IDI I think.
And on the 944 turbo, it might not be so bad if you've got good exhaust flow, but then I'm no expert on that turbo (or any for that matter)
Reply #2February 08, 2006, 10:46:51 pm
dubCanuck1
  • 279
« Reply #2 on: February 08, 2006, 10:46:51 pm »
Under pain of death. :D
