Author Topic: Pulsing clear fuel line  (Read 4799 times)
February 05, 2012, 07:13:46 pm
2strokesmoke
« on: February 05, 2012, 07:13:46 pm »
Hey guys,
On my 1.6TD I have noticed that the new clear fuel line (from filter to IP) is pulsing.
It's more noticable at lower RPM.
Could this be a stuck pump vane ?
The pump did sit dry (without any caps) for at least 6 months,maybe even a year.
( this is a Fox TD build I purchased,that wasn't completed- so I don't know how long the IP sat dry for sure)
When I resealed the IP and did Gov Mod, I filled the IP with trans fluid,which sat this way for about 3 weeks,before I finished the swap and started the engine.
I don't have a pressure gauge setup,to measure IP internal Pressure.
I've never seen a fuel line pulse like this before.
The only thing I can think of ,is a stuck pump vane ?
Any other ideas and remidies?
Do you think it will free itself upon operation ?
Will any fuel treatments help? (if it's a stuck vane)
Or do I have to tear the IP apart?
I have never dismantled an entire pump before- Been lucky I guess-
Here is a link to the build on the vortex:
http://forums.vwvortex.com/showthread.php?5186163-JGWarner-s-Turbo-Diesel-Fox
Thanks for your input !
Mike
Reply #1February 05, 2012, 09:08:46 pm
Re: Pulsing clear fuel line
« Reply #1 on: February 05, 2012, 09:08:46 pm »
If you filled it with trans fluid what kind are we talking here?  75W or 90W?  Or do you mean Automatic Transmission fluid?  If ATF for that amount of time I would expect it to be free but perhaps you may need a purge treatment instead.  Otherwise a teardown and free that vane that seems to be sticking.  Might actually be two of them.
Reply #2February 05, 2012, 10:36:13 pm
« Reply #2 on: February 05, 2012, 10:36:13 pm »
it is the feed line pulsing? Is it just a super flexible line??
The injection pump does put that line under suction to pull the fuel from the tank.. it may just be a soft line.
Reply #3February 06, 2012, 08:18:08 am
« Reply #3 on: February 06, 2012, 08:18:08 am »
It's alive!   Talk about a Franken motor.
Reply #4February 06, 2012, 10:27:33 am
2strokesmoke
« Reply #4 on: February 06, 2012, 10:27:33 am »
Hi Guys,
Thanks for the replies !
Sorry- Yes I used ATF in IP upon reseal.
The clear fuel line is very flexible or soft
At idle it pulses 1-2 times per second
I guess the only way I will know for sure,is to measure IP internal pressure.
Does anyone have a return banjo and bolt-they want to sell ? So I can make a gauge setup.
I'm wondering if I could drain fuel filter and fill it with PB Blaster- let it run for a bit-then stut it down and let it sit for several days or a week.
Maybe this would free up a stuck vane?
I imagine the engine would run on PB Blaster- they seem to run on just about anything ! LOL
What do you think ?
Thanks,Mike
Reply #5February 07, 2012, 09:02:05 pm
2strokesmoke
« Reply #5 on: February 07, 2012, 09:02:05 pm »
Has anyone ever tried filling the IP with penetrant,to free up frozen vanes or internals?
Has anyone had the vanes free up after driving the vehicle?
Thanks,Mike
