Author Topic: Glowplug Checking?  (Read 3567 times)
July 27, 2004, 12:42:15 pm
BigggWilly
  • 25
Glowplug Checking?
« on: July 27, 2004, 12:42:15 pm »
Hey guys,
Lately my car has required excessive cranking to get it started after sitting cold for a while, sometimes even 3-4 seconds of cranking. (Unless I wait for the actual glow plug relay click instead of just the light).
I was thinking that its either my glowplugs, or a fuel leak somewhere. I think it would easier to test the glowplugs first, but I really don't know how.
What are the symptoms of malfunctioning glowplugs? Will the conduct electricity if they are working/not working? Do they have a specific resistance?
What’s the best way to check to see if my glowplugs are working?
Thanks a lot guys!
Will Pomeroy.
Reply #1July 27, 2004, 06:43:52 pm
janb
  • 167
Glowplug Checking?
« Reply #1 on: July 27, 2004, 06:43:52 pm »
first check that relay and strip fuse are ok, by checking power at 1st plug / buss bar
for quick and ez GP check, I use a test light ($0.99) disconnect all but one plug from Buss bar, check each plug for continuity at tip (with bat +)  no light = bad plug   Warning, it is possible to have a bad plug, and have continuity (bit rare, cause = partial burn-out)
more intructions go to tech section here
 http://www.vwdieselparts.com/
The Stealth Rabbit
VW-d's are forever
