Author Topic: Good, flexible, clear tubing for fuel lines.  (Read 17180 times)
Reply #15January 24, 2012, 10:24:13 am
ToddA1
  • 434
Re: Good, flexible, clear tubing for fuel lines.
« Reply #15 on: January 24, 2012, 10:24:13 am »
Not sure what you're looking at, but there isn't a kill switch installed.
The only thing that's out of place is the fuse holder on top of the washer bottle and the Ford starter solenoid and GP fuse holder on the raintray.
-Todd
Reply #16January 24, 2012, 10:54:33 am
  • 4553
« Reply #16 on: January 24, 2012, 10:54:33 am »
Fuse holder on Water bottle had my attention.  But that Wire?
Reply #17January 24, 2012, 11:00:04 am
« Reply #17 on: January 24, 2012, 11:00:04 am »
that wirreee.. that wiree has seen alotta love but its never gonna see another love like me...
sorry, sometimes I sing. I LOVE THAT WIRE! omf. its incredible.
Reply #18January 24, 2012, 11:31:30 am
  • 4553
« Reply #18 on: January 24, 2012, 11:31:30 am »
I got it.  Should the car not be able to start the cable comes off, gets wrapped around the bumper supports and becomes the tow it home cable.  Genius.
Reply #19January 24, 2012, 12:25:15 pm
ToddA1
  • 434
« Reply #19 on: January 24, 2012, 12:25:15 pm »
http://www.knukonceptz.com/productDetail.cfm?prodID=KFX0R
When I say this stuff is flexible, I'm not joking.  It's like a wet noodle.  I compared it to some some 1/0 Streetwires, and it was a totally different experience.  There's a really tight hair pin bend under the battery tray (service loop) and the Streetwires stuff would have never done that.  Comparing the two, the Streetwires stuff also seemed undersized.
The fuseholder came from the same place.
http://www.knukonceptz.com/productDetail.cfm?prodID=KNF-23
-Todd
Reply #20January 24, 2012, 04:57:46 pm
« Reply #20 on: January 24, 2012, 04:57:46 pm »
HOLY BATTERY CABLE!!
Haha...  1/0 ga.  Incredibly flexible, too.  Never worked with anything like it, before.
-Todd
I used 1/0 as well, but not transparent. Super flexible fine wire, good for starting.
Reply #21January 24, 2012, 05:44:48 pm
  • 4553
« Reply #21 on: January 24, 2012, 05:44:48 pm »
This seems to be the case where more is better.  5400 plus wires and it can handle up to 300 amps.  That should do for just about any of our GP, starter needs.  Maybe some subwoofers would press it.
Nice product.
Reply #22January 24, 2012, 05:58:14 pm
BigVWman
  • 332
« Reply #22 on: January 24, 2012, 05:58:14 pm »
How is the jacket on that wire? I would just be concerned with the positive cable sitting the negative post longterm unless your dubs vibrate much less than mine! or is that a illusion they are that close in the picture?
How does the plain old clear vinyl fuel line hold up longterm?
« Last Edit: January 24, 2012, 06:00:24 pm by BigVWman »
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #23January 24, 2012, 06:54:34 pm
ToddA1
  • 434
« Reply #23 on: January 24, 2012, 06:54:34 pm »
That stuff is rated to 375A @ 20'.  I've run some pretty powerful sub/amp combos in my younger days and I can assure you that I never came close to maxing out my 2 ga. wire.  Touching on an earlier comment I made about Streetwires looking undersized is partially true.  I just read that the cable I used is purposely made oversized.
The spec sheet says the insulation is 2mm... slightly over 1/16".  It's an illusion about any contact; the cables are on an upward sweep at that point; they were at least 1/2" away from the negative terminal.
Back on topic about the lines, lol.  I used    5384K604 (3/16" ID 5/16" OD) and 5384K57 (1/4" ID 3/8" OD) Moisture-resistant Polyethylene Vacuum Tubing.  I just saw that it's not recommended, but I drove the car for at least 6 months with those lines on it and had no issues. I guess you're taking the same chance if you use the clear vinyl tubing.
Not sure if I made a mistake when I ordered it, but I should have used 50375K45 (3/16" ID 5/16" OD) and 50375K47  (1/4" ID 3/8" OD) High-Pressure Polyethylene Vacuum Tubing.  From the rating table for diesel: No Effect—Excellent chemical resistance. No performance degradation.
-Todd
Reply #24February 25, 2012, 03:27:51 pm
« Reply #24 on: February 25, 2012, 03:27:51 pm »
I know I'm kind of late to this but here's what I'm using for a "clear section of fuel line."
Reply #25February 25, 2012, 05:28:09 pm
  • 4553
« Reply #25 on: February 25, 2012, 05:28:09 pm »
Ah the ubber short version with filtration added for extra grins and giggles.
Reply #26February 26, 2012, 02:26:58 am
« Reply #26 on: February 26, 2012, 02:26:58 am »
I had one of those till one day I got on it, stripped the threads, and blew my fuel all over the street :-[
I think some of those are more equal than others.
I just replaced some  cross weave reinforced ?nylon?  from the hardware store after 5 years.  It wasn't causing me problems, but wasn't as supple as it used to be either.
Reply #27February 26, 2012, 03:48:51 pm
sdwarf36
  • 159
91 Jetta on WVO na / td swap in progress.
 "VW happiness is having 4 working door handles."
Reply #28February 26, 2012, 05:19:51 pm
Baron VonZeppelin
« Reply #28 on: February 26, 2012, 05:19:51 pm »
I've got almost 3 years on some of the cheap vinyl (10-20 cents per foot) from like Lowes/Tractor Supply/Hammerhead Hdwr. In use just underhood, on Supply and Return.
On injector jumpers, and from Inj Pump to Injector, i use thicker walled tygon.
The 1/8" vinyl is too thin walled and it splits on the ends.
The vinyl "might" go 5 years.
Have it on 4 cars so far.
Reply #29February 27, 2012, 08:13:21 am
bbob203
  • 1789
« Reply #29 on: February 27, 2012, 08:13:21 am »
i use some blue poly stuff from a motorcycle shop. tis cheap and durable as heck.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
