Author Topic: Shift gates totally wonky  (Read 5689 times)
February 07, 2006, 09:18:51 am
bhtooefr
  • 305
    • http://my.opera.com/bhtooefr
« on: February 07, 2006, 09:18:51 am »
The top is the normal shift pattern, with red being the reverse lockout.
The bottom is my shift pattern. Wonky, huh?
(Of course, the gears are: top row: R135, bottom row: 24)
I'm suspecting shift bushings, but I don't want to just throw parts at the problem.
1986 Volkswagen Golf | 1.6L NA diesel | 5spd manual | Deep Cosmic Blue (LE5C) | aack, it's a parts car, now, too!
1992 Mazda Miata | 1.6L DOHC gasser | 5spd manual | Classic Red (SU)
Reply #1February 08, 2006, 05:25:35 am
bryanbryan89x
  • 110
« Reply #1 on: February 08, 2006, 05:25:35 am »
Does your shifter move from side to side when its in gear?
1981, Rabbit Car, 1.6, N.A.
Reply #2February 08, 2006, 02:33:09 pm
bhtooefr
  • 305
« Reply #2 on: February 08, 2006, 02:33:09 pm »
Yes, it does. I'm assuming that that means that my theory about the bushings is right?
Reply #3February 08, 2006, 03:21:45 pm
wyldman
  • Authorized Vendor
  • 403
« Reply #3 on: February 08, 2006, 03:21:45 pm »
Replace the shifter bushings,and anything else in there that's loose.You should be able to reach down from up top under the hood,and grab the linkage to see what all is gone.
Auto Proformance Services - VW Diesel parts and service
(416)565-7282
Reply #4February 08, 2006, 04:22:48 pm
bryanbryan89x
  • 110
« Reply #4 on: February 08, 2006, 04:22:48 pm »
The parts place in Michigan sells a good kit.  It comes with the arms and all the bushings.  I think it is around $20.  In the bentley it shows how everything goes together really top notch diagram.
Reply #5February 09, 2006, 06:00:31 am
bhtooefr
  • 305
« Reply #5 on: February 09, 2006, 06:00:31 am »
Ended up just getting this for $15.95 shipped off of an eBay store:
Yep, includes a couple rods, too.
Also, what repair group is the shifter bushing stuff under? 34 - Maunal Transmission - Controls? (Mine's the 85-only edition.)
Or, should I just look on the ep0niks version?
Edit: Ah, didn't make it clear that that's the product photo that the seller used. I ordered it last night ;)
Reply #6February 15, 2006, 01:32:03 pm
bhtooefr
  • 305
« Reply #6 on: February 15, 2006, 01:32:03 pm »
OK, guys...
Procedure for installing this?
Can't find any Bentley that has one.
Reply #7February 15, 2006, 04:29:03 pm
bhtooefr
  • 305
« Reply #7 on: February 15, 2006, 04:29:03 pm »
Bumping.
See the part on the upper left of the product pic?
That's the worn part on my car.
How do I remove the old one?
Reply #8February 15, 2006, 05:18:09 pm
mortskeg
  • 95
    • http://www.vwcaddy.com
« Reply #8 on: February 15, 2006, 05:18:09 pm »
Hey bhtooefr,
I think you're asking about the small plasic linkage right?  If that's the case then all you need to do is unsnap the plastic clasps- I like to use a small flat-head screwdriver.  Then using the same screwdriver or a bigger one pop the ball sockets off the metal balls.  Don't forget to put some compatable lube on the new one (and the rest of the linkage parts) to have that nice smooth shifter feel.
Hope this helps.
Reply #9February 15, 2006, 06:29:55 pm
bhtooefr
  • 305
« Reply #9 on: February 15, 2006, 06:29:55 pm »
Wow, one post that did what ten did on the Vhortex!
Yes, I got the lube that the ep0niks Bentley recommended. G 000 602, which has been replaced by a much less memorable part number. It's molybdenum bisulfide grease, or high-melting point CV joint grease.
$14.something for 120 grams. I guess I should use the leftovers to lube up for next time I need to get lubes from my local stealership (and I even get wholesale prices there, all because I'm on one forum).
