Author Topic: WTB: MK2 Turbo Diesel Exhaust Manifold  (Read 7167 times)
January 15, 2012, 10:32:03 am
idlbk
  • 12
« on: January 15, 2012, 10:32:03 am »
Hello all,
In the middle of an AAZ conversion in my 82 Vanagon and looking for an MK2 Jetta or Golf Turbo Diesel Exhaust Manifold to bolt up to a K03 turbo (kind of looking for that as well). If any one has one out there I would be most interested.
Thanks!
Reply #1January 15, 2012, 11:55:13 am
Re: WTB: MK2 Turbo Diesel Exhaust Manifold
« Reply #1 on: January 15, 2012, 11:55:13 am »
Hello all,
Thanks!
you wont find a mk2 manifold to bolt up to a K03 unless you build/buy an adapter..
Reply #2January 15, 2012, 12:40:27 pm
Alleslowbuged
  • 270
« Reply #2 on: January 15, 2012, 12:40:27 pm »
Hi,
i think i have both, manifold and turbo from a MKIII AAZ, but i am in germany where are you from?
Best Regards
Alleslowbuged
VW Golf Mk1 (Typ 17) 1981 with 1.6 TD
BMW E28 524 TD
Reply #3January 15, 2012, 12:57:13 pm
« Reply #3 on: January 15, 2012, 12:57:13 pm »
you will have room issus... you wanna find a quantium manifold and proper euro turbo. its smaller then the quantium one..
Reply #4January 15, 2012, 01:02:17 pm
« Reply #4 on: January 15, 2012, 01:02:17 pm »
whats the diff between a US spec Quantum, and a EURO Quantum?
Reply #5January 15, 2012, 01:05:48 pm
idlbk
  • 12
« Reply #5 on: January 15, 2012, 01:05:48 pm »
Yes, I have been currently running the 1.6 TD vanagon setup, same as the euro Quantum I am told.  This fits quite well but I am looking to upgrade for a bit of a better capacity turbo for the AAZ.  I am told that the MK2 TD manifold and a K03 will require a small modification to the drivers side motor mount to clear.
Reply #6January 15, 2012, 01:07:46 pm
idlbk
  • 12
« Reply #6 on: January 15, 2012, 01:07:46 pm »
Hi,
Best Regards
Alleslowbuged
I am in Brooklyn, NY.  Would you happen to have a photo of the manifold and turbo?  I am still a little unsure if it will work with my setup.
All best...
Jason
Reply #7January 15, 2012, 01:20:47 pm
« Reply #7 on: January 15, 2012, 01:20:47 pm »
the quantum manifold mounts the turbo low, and more to the front of the engine..
i remember the mk2 manifold DOES NOT FIT in a vanagon application..
CRSMP5 is a sharp cookie.. what he says is the truth.. hes been there and done that a few times..
Reply #8January 15, 2012, 01:24:35 pm
idlbk
  • 12
« Reply #8 on: January 15, 2012, 01:24:35 pm »
Has anyone out here installed a turbo on an AAZ in a Vanagon?  I would be interested in hearing about what setup you used.  I seem to be getting conflicting information, you know...  4 diesel guys, 5 opinions...
Reply #9January 15, 2012, 01:35:50 pm
« Reply #9 on: January 15, 2012, 01:35:50 pm »
search, our search function actually does work, unlike the vortex search..
its been done LOTS.. and from what i remember, people usually use the longitudinal turbo/manifolds..
Reply #10January 15, 2012, 02:19:42 pm
« Reply #10 on: January 15, 2012, 02:19:42 pm »
i refer to the vanagon td turbo from europe is smaller then quantium.. so a quantium turbo would be bigger and a gain in boost.. but also a gain in lag..
myke_w who used to be a mod here did the euro set up in his.. i saw his in person...
what you seek is the turbo, manifolds, oil lines from a quantium td... as they never sold a td vanagon in the us... as stated the turbo on a vanagon was smaller then a quantium.. and the quantium is actually larger then mk1/mk2 td golf/jetta..
so that is what you will want to seek... just relize its size is a bit big and will have some lag..
now why others do not fit.. think the engine mount is in the way...
Reply #11January 15, 2012, 02:23:24 pm
« Reply #11 on: January 15, 2012, 02:23:24 pm »
bumped toby's post for you... no idea if still has.. but dasher/fox is same set up as quantium.. well they never made them td.. so it i squantium stuff..
Reply #12January 15, 2012, 02:30:07 pm
« Reply #12 on: January 15, 2012, 02:30:07 pm »
they never sold a TD Vanagon? in USA? maybe in canada? ive seen one before.. it looked STOCK.. or else the person who converted it, went to great lengths to make it appear stock 8)
Reply #13January 15, 2012, 07:01:55 pm
idlbk
  • 12
« Reply #13 on: January 15, 2012, 07:01:55 pm »
Thanks CRSMP5.  Yea, I have the smaller vanagon 1.6 TD setup that i believe was either imported from Canada or Europe by the previous owner.  Due to a dropped exhaust valve I am replacing the motor with an AAZ and have been looking for a turbo setup to possibly upgrade to in the future.  We are going to retain the 1.6 turbo setup for now to get it back on the road but I was told that this setup is a bit restrictive on an AAZ.  Does the larger US Quantum turbo mate up to the same manifold as the Vanagon 1.6TD setup?
I am really not all too concerned with crazy performance so I am not looking to push it to its limits, just want to be able to hold 65mph on the road without stressing the engine beyond its comfort range.  I do have a 5-speed tranny so I should have the gearing to get me there, thinking about upgrading to 15" wheels in the near future as well.
Thanks for all the great info...
Reply #14January 15, 2012, 08:18:42 pm
« Reply #14 on: January 15, 2012, 08:18:42 pm »
myke's looked show room stock... but it was a convert.. so yea.. people build them... and when money spent properly. are impressive to see.. but still slow.. LOL..
if you indeed have a vanagon td set up... yes the quantium turbo is direct fit.. now if its some other turbo set up.. no... how bout posting pics of what you have?
i still cannot do a vanagon.. weight too much.. and unimpressed..
