Author Topic: 80% peloquin shim kit  (Read 34560 times)
Reply #45September 20, 2012, 06:55:14 am
SR Heer
  • 199
Re: 80% peloquin shim kit
« Reply #45 on: September 20, 2012, 06:55:14 am »
Good idea - was thinking the same - so did you countersink the retaining washer more or the diferencial axles or both - and does anyone know how much side to side (in and out slack - back and forth ) play is needed on CV axle ? I could have check on my stock ones but they are out already - I would guess about 1/2 inch - that way one could check before they test drive with modified axles and shim kit  - one could take visegrips and clamp on to help in moving and measuring differences.
« Last Edit: September 20, 2012, 07:44:31 am by SR Heer »
97 Passat 1Z, 98 Jetta AHU, 91 Jetta AAZ TD, and 81 Rabbit Pickup
Reply #46September 20, 2012, 01:50:11 pm
bbob203
  • 1789
« Reply #46 on: September 20, 2012, 01:50:11 pm »
I change the pitch on the bolt head to countersink it more.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #47September 20, 2012, 02:23:34 pm
SR Heer
  • 199
« Reply #47 on: September 20, 2012, 02:23:34 pm »
if you are not a machinist bbob203 then how?
Reply #48September 20, 2012, 06:18:52 pm
« Reply #48 on: September 20, 2012, 06:18:52 pm »
Taking down the OD of the flat head
Reply #49September 20, 2012, 06:23:36 pm
bbob203
  • 1789
« Reply #49 on: September 20, 2012, 06:23:36 pm »
a bench grinder setup by a former detroit machinist with diamond file a good eye and a some time.
03 Jetta wagon TDi
Reply #50September 20, 2012, 06:24:31 pm
bbob203
  • 1789
« Reply #50 on: September 20, 2012, 06:24:31 pm »
I essentially made the head smaller from all directions.
03 Jetta wagon TDi
Reply #51September 20, 2012, 06:44:07 pm
« Reply #51 on: September 20, 2012, 06:44:07 pm »
almost like you reduced the OD of the flat head.
Reply #52September 20, 2012, 06:50:51 pm
bbob203
  • 1789
« Reply #52 on: September 20, 2012, 06:50:51 pm »
yep pretty much. I got one totally flush with the cap that one will go on the drivers side. the other isn't flash but I've reduced its stack height significatly and the od of the head. I've ground about a millimeter off the driver side axle.
03 Jetta wagon TDi
Reply #53September 23, 2012, 02:48:11 am
bbob203
  • 1789
« Reply #53 on: September 23, 2012, 02:48:11 am »
Caps and bolts are in when i was torquing the bolt i visibly saw the flange move 1/8th-1/4in towards the case on both sides.
03 Jetta wagon TDi
Reply #54September 23, 2012, 06:37:53 am
« Reply #54 on: September 23, 2012, 06:37:53 am »
Very nice, bbob were you the one to buy the stuff from a hardware store to make your own? I cannot recall from the thread.
Reply #55September 23, 2012, 07:14:25 am
SR Heer
  • 199
« Reply #55 on: September 23, 2012, 07:14:25 am »
Reply #56September 23, 2012, 07:22:16 am
bbob203
  • 1789
« Reply #56 on: September 23, 2012, 07:22:16 am »
well sort of... what I did was bought the inner washers from hardware store (40% kit) and the caps and flange bolts from peloquins. I ground the heads of the bolts supplied by peloquins down to fit better into the countersinks of the caps from peloquins.
03 Jetta wagon TDi
Reply #57October 19, 2012, 09:24:53 pm
SR Heer
  • 199
« Reply #57 on: October 19, 2012, 09:24:53 pm »
bbob203 - I just wanted to check to see if you had any first hand results from your shim kit implimention
thanks for your time!
Reply #58October 20, 2012, 12:09:10 am
bbob203
  • 1789
« Reply #58 on: October 20, 2012, 12:09:10 am »
the car is like 5 bolts away from driving ill report back tomorrow after noon.
03 Jetta wagon TDi
Reply #59October 20, 2012, 05:42:27 pm
« Reply #59 on: October 20, 2012, 05:42:27 pm »
Yes I too, am extremely interested on this matter. Good luck!
