General Information
Upgrades (non engine related )
80% peloquin shim kit
Pages:
4
5
Topic: 80% peloquin shim kit (Read 34538 times)
Reply #15
July 25, 2012, 05:55:46 pm
Re: 80% peloquin shim kit
Reply #15 on:
July 25, 2012, 05:55:46 pm »
Not too shabby. How does it feel? Do any field testing?
Reply #16
July 25, 2012, 06:03:50 pm
bbob203
Reply #16 on:
July 25, 2012, 06:03:50 pm »
Quote from: 8v-of-fury on July 25, 2012, 05:55:46 pm
not yet hopefully next weekish the car will be on the road i will report back my findings. Biggest reason im interested in this is for snow driving i hear it can help quite a bit.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #17
July 25, 2012, 06:18:29 pm
Reply #17 on:
July 25, 2012, 06:18:29 pm »
Yes me as well. I have a bit of torque to the wheels with the AHU.. so I need more traction too! LOL
Reply #18
August 18, 2012, 02:39:07 pm
bbob203
Reply #18 on:
August 18, 2012, 02:39:07 pm »
Haven't installed trans into car yet to road test but on the bench it feels like it takes more force to spin the flanges in opposite directions....
03 Jetta wagon TDi
Reply #19
August 28, 2012, 05:15:31 pm
SR Heer
Reply #19 on:
August 28, 2012, 05:15:31 pm »
I have an extra 2Y - close ratio 020 trans with 100mm flanges - whats saying I cannot remove those and put onto a late FF 90mm flanged 020 tranny along with the 80% kit before I couple up to 1.6TD going into Caddy?
97 Passat 1Z, 98 Jetta AHU, 91 Jetta AAZ TD, and 81 Rabbit Pickup
Reply #20
August 28, 2012, 06:28:34 pm
Reply #20 on:
August 28, 2012, 06:28:34 pm »
Doable. Year dependent on the FF though I think.
http://brokevw.com/flanges.html
Reply #21
August 28, 2012, 06:52:23 pm
SR Heer
Reply #21 on:
August 28, 2012, 06:52:23 pm »
thanks 8VofFurry - thats what I need to figure out!
Reply #22
August 30, 2012, 10:31:28 am
bbob203
Reply #22 on:
August 30, 2012, 10:31:28 am »
Gary is sending me the bolts and sealing caps for 25 bucks plus shipping so i save my self about 60 bucks.
03 Jetta wagon TDi
Reply #23
August 30, 2012, 07:15:48 pm
SR Heer
Reply #23 on:
August 30, 2012, 07:15:48 pm »
Acording to Brian the reason the CV axle shaft still hits is because the 100mm flanges are taller than 90mm flanges and so that is advantage of staying with 90mm verses 100 - he said kits work fine with 90mms just have to grind a bit off edge of side bolts that sticks over end and grind end of CV axle down a bit since the shims add a bit more total material - makeing cleance between former ouput flange and end of CV axle less
Reply #24
August 30, 2012, 08:05:15 pm
Reply #24 on:
August 30, 2012, 08:05:15 pm »
It seems an easy job for sure, but I have lifetime $$$ axles in there right now.. and I doubt they'd cover them for whatever reason down the road if there is material physically missing from it..
LOL
Reply #25
August 31, 2012, 04:23:44 am
Reply #25 on:
August 31, 2012, 04:23:44 am »
They do
. I have the lifetime warranty ones as well and eventhough I swapped 100mm flanges the ones I got I do not believe were OEM VW cores. The shaft from the snap ring toward the flange was too long and on the driver side unscrewed on me and the inner joint ate the bolt. I got another and ground it down real thin, when the boot went bad they took it with no questions asked. I did do a good job grinding it so that it didn't look like a beaver went to town on it, it looked nice and flat and with tons of CV grease I am sure no one even blinked an eye.
Round 2
Reply #26
August 31, 2012, 06:47:40 am
Reply #26 on:
August 31, 2012, 06:47:40 am »
Beaveerrsss. HHaha. Yeah well i may just pull em and get this 80% kit.. Gonna need it for the snow in a month and a bit lol!!
Reply #27
August 31, 2012, 11:04:45 am
bbob203
Reply #27 on:
August 31, 2012, 11:04:45 am »
so essentially if 90mm are used its 100 percent needed to grind down the axle shaft? lowered or not..
03 Jetta wagon TDi
Reply #28
August 31, 2012, 12:07:20 pm
SR Heer
Reply #28 on:
August 31, 2012, 12:07:20 pm »
no - as I understand it grinding for 90mms verses what is needed on 100mm set up is on totally different parts
Reply #29
August 31, 2012, 02:11:11 pm
Reply #29 on:
August 31, 2012, 02:11:11 pm »
No again, I spoke with the guy that builds the 80% kit. He said grind if 90mm. They are ok if 100mm, stock height....BUT he was wrong. Mine is stock, not lowered at all and I went to the 100mm and the inner bolt with the 80% kit unthreaded and the CV ate it. I compared the stubs of a 90mm and the 100mm that I had and saw that the 100mm was a lot longer and that is why it did it. So I ground the new one and didn't have an issue since.
Round 2
Pages:
4
5
General Information
