Author Topic: 1.6TD build.  (Read 6758 times)
Reply #15January 11, 2012, 11:15:18 am
Alleslowbuged
  • 270
Re: 1.6TD build.
« Reply #15 on: January 11, 2012, 11:15:18 am »
Hi,
pherhaps i did not have write it correct, the spec is not a stock TDI spec, but it is the same spec as the stage 3 TDI (1.9 ltr. 8V) spec from Dbilias.
Best Regards
Alleslowbuged
VW Golf Mk1 (Typ 17) 1981 with 1.6 TD
BMW E28 524 TD
Reply #16January 11, 2012, 11:33:50 am
MJF
  • 581
Re: 1.6TD build.
« Reply #16 on: January 11, 2012, 11:33:50 am »
Really?  Worked in my Audi's, just as stated.  Not anything I'm gonna do again but they ran, not too well either.
I thought base circles were the same but the loading just came on differently between the two styles of cams. But I could easily be wrong and I only have solid lifter cams at my house or I would just go check.
As far as a gt20 which one?  And what do you want from your car
yea guys, there different.. let me go check, i have a solid diesel cam, and a hydro gas cam to check..
Solid and hydraulic diesel cams have same basic sircle, gasser cams has differences. Mech cams has lash ramps at the beginnning and at the end of cam profile. TD and NA has same cams, at least part number is same.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #17January 11, 2012, 12:57:52 pm
Re: 1.6TD build.
« Reply #17 on: January 11, 2012, 12:57:52 pm »
heres what i was looking for from this thread http://www.vwdiesel.net/forum/index.php?topic=25149
Reply #18January 11, 2012, 04:07:36 pm
BillyWillicker
  • 111
Re: 1.6TD build.
« Reply #18 on: January 11, 2012, 04:07:36 pm »
Do you guys think I could put an '84 GTI cam in and make it work if degree'd right?  That cam is solid lifter and should be a better profile.  I think so, if I use a 16v vernier cam sprocket and adjust it correctly?
Anyways, on the turbo.  I have been using the turbo calculator on not2fast, it is a pretty comprehensive tool.  What it calculates looks REALLY good on the comp. map of a Garrett GT2052(2).  It maps out very nicely and could be used alone with boost at 6-20psi from 2200-6000rpm, or as the small turbo for a compound setup for HUGE HP.
The calculator comes up with 185hp and a BMEP of 250psi, which is fairly conservative.  These numbers are ROUGH numbers though but the airflow calcs and maps look right.
Any experience with a GT2052 on a 1.6l TD anyone?
Reply #19January 12, 2012, 06:43:23 am
Re: 1.6TD build.
« Reply #19 on: January 12, 2012, 06:43:23 am »
no gasser cam will work in a diesel.. too much overlap. if you got it to turn over, there would be piston to valve contact.
Reply #20January 12, 2012, 07:39:00 am
Alleslowbuged
  • 270
Re: 1.6TD build.
« Reply #20 on: January 12, 2012, 07:39:00 am »
Hi,
i know two guys who have run an AAZ (and later an 1Z) with a gasser (gti) cam and they was happy with the cam.
For sure they have make extra place for valves, otherwise the valve would have said hello to the pistons.
Best Regards
BMW E28 524 TD
Reply #21January 12, 2012, 07:58:08 am
Re: 1.6TD build.
« Reply #21 on: January 12, 2012, 07:58:08 am »
Hi,
Best Regards
well, that would definitely drop the compression, cutting valve reliefs in the pistons..
how bout some specifics on what they did? just cut valve reliefs and dropped in a gasser cam?
how did they deal with the smaller base circle?
Reply #22January 12, 2012, 01:39:54 pm
BillyWillicker
  • 111
Re: 1.6TD build.
« Reply #22 on: January 12, 2012, 01:39:54 pm »
Most likely they did exactly that.  If you look at the cam profile pic above you can see that the overlap can be centered out to make it VERY close to the solid TD cam profile at low lifts.  It shouldn't take too much to make it work.  I plan on putting a bunch of time/effort into making this motor the best it cam be, and usually the more time/effort you put into something the more work you get out of it afterwards.
