Author Topic: 36mm oil pump?  (Read 7444 times)
January 08, 2012, 02:56:59 pm
silvertdvw
  • 38
36mm oil pump?
« on: January 08, 2012, 02:56:59 pm »
I want to change my 30mm oil pump out for a 36mm pump just for a little extra pressure, I'm running a franken 1.6/1.9 combo at 25psi. Do i just order a pump for an aaz?
I got a pump for a 92 1.6 but they gave me a 30mm one did they just give me the wrong part? I read here that anything after 86 should have the 36mm pump.
« Last Edit: January 08, 2012, 03:01:02 pm by silvertdvw »
Reply #1January 08, 2012, 03:01:31 pm
rallydiesel
  • 1880
Re: 36mm oil pump?
« Reply #1 on: January 08, 2012, 03:01:31 pm »
I've got a 36mm pump if you want used.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2January 09, 2012, 10:18:34 pm
steevz
  • 229
Re: 36mm oil pump?
« Reply #2 on: January 09, 2012, 10:18:34 pm »
I bought a new oil pump. For AAZand it was a new Meyle pump. It was only 30mm gears, took it back. This was about 2 weeks ago.
Reply #3January 10, 2012, 07:52:54 am
Re: 36mm oil pump?
« Reply #3 on: January 10, 2012, 07:52:54 am »
30mm pumps are NOT correct for hydro/turbo engines.. FWIW
Reply #4January 10, 2012, 11:12:13 am
BillyWillicker
  • 111
Re: 36mm oil pump?
« Reply #4 on: January 10, 2012, 11:12:13 am »
Yea, oil pumps are specifically sized to each engines specific flow requirements/leakoff.  Ever notice how ALL VAG engines oil pressure acts the same?  All the 4 cylinder VW's, 5 cylinder audi's, even v8 audi, turbo or not, start at over 5bar on the gauge and drop to just over 1bar on hot idle.  The only one that has acted differently than this was the WE 5 cylinder solid lifter non turbo in my early build 84 coupe GT, it would run at 2bar hot idle-less leakoff in that one with the same oil pump as the hydro turbo 5.
This includes..
  Audi 3.6l PT v8
  Audi 2.2l MC turbo hydro i5
  Audi 2.2l KH hydro i5
  VW 1.8l hydro i4
  Audi 2.3l 7A 20v hydro i5
  VW 1.6l ME solid diesel
  Audi 2.1l WE solid i5
  Audi 2.0l 3A hydro i4
In short, I would make sure I have the right oil pump and make sure ALL the bearings are good.
« Last Edit: January 10, 2012, 12:36:13 pm by BillyWillicker »
Reply #5January 28, 2012, 09:30:52 am
silvertdvw
  • 38
Re: 36mm oil pump?
« Reply #5 on: January 28, 2012, 09:30:52 am »
Ya i've been trying to get a new pump, but all i can find is the 30mm pumps. You still have that pump rallydiesel? someone must know where to find these?? p/n's??
Reply #6January 28, 2012, 09:53:04 am
Re: 36mm oil pump?
« Reply #6 on: January 28, 2012, 09:53:04 am »
http://www.partsplaceinc.com/ has them, I bought one from them. Call them.
I don't think it was OEM, it was made in Brazil but it seems to be working good.
The larger oil pump is the right oil pump. The early TD engines had low oil pressure after a while, even with the bearings still in decent shape. This is a known issue.
The anemic 26 mm pumps used in some of the early TD blocks, or even the 30 mm pumps just don't cut the mustard when you run a hydraulic head, turbo, oil squirters etc...
You might say "whatever VW used was good enough" but remember, running these engines at 25 psi or for 350,000 miles was never part of their business model.
Reply #7January 28, 2012, 10:20:06 am
rallydiesel
  • 1880
Re: 36mm oil pump?
« Reply #7 on: January 28, 2012, 10:20:06 am »
Yes I still have it. PM me if you want it. I will check the lash to make sure it's still good if you do. It was in good condition when I took it out.
Reply #8January 28, 2012, 11:47:05 am
BillyWillicker
  • 111
Re: 36mm oil pump?
« Reply #8 on: January 28, 2012, 11:47:05 am »
Any ABA gasser oil pump is 36mm!
Reply #9January 28, 2012, 04:50:06 pm
Powered by Spearco
  • 1203
Re: 36mm oil pump?
« Reply #9 on: January 28, 2012, 04:50:06 pm »
I took a 16V oil pump which has 36mm gears and pressed off the shaft for drive on the Int. shaft gear and pressed on the shaft for the Vacuum pump delete. Does that make sense?
Works perfect.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #10January 30, 2012, 11:58:06 am
rabbitman
  • 2788
Re: 36mm oil pump?
« Reply #10 on: January 30, 2012, 11:58:06 am »
Reply #11January 31, 2012, 09:37:11 pm
Re: 36mm oil pump?
« Reply #11 on: January 31, 2012, 09:37:11 pm »
But they spin the wrong way.
At least I thought that was the difference between the gas and diesel pumps because of how the timing belt is routed.
Reply #12January 31, 2012, 10:17:18 pm
Powered by Spearco
  • 1203
Re: 36mm oil pump?
« Reply #12 on: January 31, 2012, 10:17:18 pm »
Yes but the gear on the shaft is the same for all oil pumps.
'13 Golf R:. Tuned
'98 Puch G320
Reply #13February 01, 2012, 09:42:04 am
Re: 36mm oil pump?
« Reply #13 on: February 01, 2012, 09:42:04 am »
diesel gear is cut backwards from a gasser gear..
the diesel IM shaft tries lifting the gear off the shaft, because its driven from the BACK of the belt..
the gasser IM shaft forces the gear down towards the block and the bronze bushing, because its driven off the FRONT side of the belt..
so, if the IM shafts spin different directions, then the gears must be cut different directions..
Reply #14February 01, 2012, 09:53:49 am
  • 2932
Re: 36mm oil pump?
« Reply #14 on: February 01, 2012, 09:53:49 am »
If the gears inside the pump were slanted that might be true.
 But they are straight cut.
