Author Topic: 1992 passat VR6 to 1.6TD swap  (Read 17329 times)
Reply #30August 10, 2012, 12:50:21 pm
Re: 1992 passat VR6 to 1.6TD swap
« Reply #30 on: August 10, 2012, 12:50:21 pm »
Easy Peasy lemon squeezy.
Rockauto.com
1991 Volkswagen Golf 1.6 N/A diesel
$19.23 :)
Reply #31August 10, 2012, 01:03:26 pm
« Reply #31 on: August 10, 2012, 01:03:26 pm »
passat tie rods longer then mk2.
Reply #32August 10, 2012, 01:19:24 pm
« Reply #32 on: August 10, 2012, 01:19:24 pm »
woops. Missed the b3 part. MY BAD! lol
Reply #33August 11, 2012, 03:00:38 am
bbob203
  • 1789
« Reply #33 on: August 11, 2012, 03:00:38 am »
I just hate p/s makes you lazy  ;D
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #34August 12, 2012, 03:26:15 am
bbob203
  • 1789
« Reply #34 on: August 12, 2012, 03:26:15 am »
crs, if you've got a tig could just chop the tie rod in the middle and weld in and extension sleeve. I doubt it would be more than inch needed to make it work.
03 Jetta wagon TDi
Reply #35August 12, 2012, 06:37:05 am
« Reply #35 on: August 12, 2012, 06:37:05 am »
any thing can be done... but there are certain things that.. well id worry about longetivity/saftey..
Reply #36August 12, 2012, 06:43:28 am
bbob203
  • 1789
« Reply #36 on: August 12, 2012, 06:43:28 am »
03 Jetta wagon TDi
Reply #37August 12, 2012, 06:44:38 am
« Reply #37 on: August 12, 2012, 06:44:38 am »
I'm still fuzzy on a couple of things:
Drive axles on the 02a ( I got some conflicting info)... which should I order?
Also wondering about radiator hoses... is something custom req'd?
Reply #38August 12, 2012, 07:04:42 am
« Reply #38 on: August 12, 2012, 07:04:42 am »
100mm joints... so 100mm flanges on tranny is all you need... gotta use the passat axles.. vr6/16v different lengths... so depending on suspention used = axle used.. but just stock passat units..
upper hose needs made up... no nipple on rad for coolent bottle.. so splice 16v upper hose w diesel upper hose... rest same...
Reply #39August 12, 2012, 07:18:25 am
« Reply #39 on: August 12, 2012, 07:18:25 am »
10-4, Thanks for the reply.
I'm sure there will be more questions about dash cluster hookups and other bits & bobs, but I'm ok with adding aftermarket guages... Heck, I drive these mk1 and mk2 rigs without any dash at all sometimes. (Just switches and dangling wires, lol.)
Reply #40August 12, 2012, 08:27:29 am
« Reply #40 on: August 12, 2012, 08:27:29 am »
i built my own cluster... sadly the fuel gauge is backwards.. aka f is empty.. and e is full... also it f when 1/4 tank.. resistance all wrong for stock sender to vdo aftermarket gauge..
why wagon on wrong coast??? front bumper toast... those wheels real soft and heavy... you will want light as possible.. and strong so they no bend on the east coast crappy potholes...
« Last Edit: August 12, 2012, 08:47:05 am by CRSMP5 »
Reply #41August 12, 2012, 10:09:30 am
bbob203
  • 1789
« Reply #41 on: August 12, 2012, 10:09:30 am »
I got free flight benefits thru job I buy cars far away in good shape and drive em home. I'm over the red one no abs for me.
03 Jetta wagon TDi
Reply #42August 13, 2012, 02:13:44 pm
bbob203
  • 1789
« Reply #42 on: August 13, 2012, 02:13:44 pm »
Tyler have you looked at 02a clutch cable conversions?
03 Jetta wagon TDi
Reply #43August 13, 2012, 02:16:47 pm
« Reply #43 on: August 13, 2012, 02:16:47 pm »
Hi Bob,
Not as yet... I got a hydraulic setup in the parts bin, but I don't know if it's in good order.
I'd be interested to know more about the cable setup - I like simple.
Reply #44August 18, 2012, 04:10:37 pm
bbob203
  • 1789
« Reply #44 on: August 18, 2012, 04:10:37 pm »
expensive kinda but how much of a hassle is hyrdraulic stuff/ cost? comparatively . More reliable for sure..
http://euro-wise.com/store/index.php?main_page=product_info&products_id=336
03 Jetta wagon TDi
