Author Topic: Pulling Engine MkI --Cherry Picker?  (Read 6088 times)
December 25, 2011, 04:15:46 am
rs899
  • 647
« on: December 25, 2011, 04:15:46 am »
For once I have the proper tool for the job , a sturdy cherry-picker type hoist and I had time to read the manual.
Bentley seems to indicate that the Mk1 engine and transmission cannot go up and out , but must go through the bottom as a unit.
Izzat so?  That would be disappointing...
Reply #1December 25, 2011, 06:04:50 am
Re: Pulling Engine MkI --Cherry Picker?
« Reply #1 on: December 25, 2011, 06:04:50 am »
U can do it either way it's easier out the bottom tho use the cherry picker to support the engine while I remove the engine mount bolts then lower it down to the griund then use the cherry picker to lift the car way up in the air and pull the engine out from under the car
Reply #2December 25, 2011, 06:12:44 am
DieselBalz
  • 301
« Reply #2 on: December 25, 2011, 06:12:44 am »
Exactly, its still gonna make the job a ton easier for ya. Instead of having a trans jack, and an engine jack, AND the jackstands all stuffed under that tiny car, you can do most the heavy lifting with the picker.
Reply #3December 25, 2011, 06:40:04 am
« Reply #3 on: December 25, 2011, 06:40:04 am »
Put the engine down onto something with wheels so that you can easily slide it out.
Reply #4December 25, 2011, 05:25:28 pm
  • 4553
« Reply #4 on: December 25, 2011, 05:25:28 pm »
Do not use nylon rope in any manner to lift either the engine or the car.  See previous threads titled Ooopppps.  Chains or properly rated lift straps.
Reply #5December 25, 2011, 08:36:30 pm
  • 2932
« Reply #5 on: December 25, 2011, 08:36:30 pm »
 There's a hole under the front motor mount.
 If you pull the radiator and front motor mount from the frame;
 there's a hole in the cross member that I stick a hook in to lift the body.
 Hook and a chain long enough to get close to the top rad support for the cherry picker to hook onto.
 Doubled-up seat belt strap works.
Reply #6December 25, 2011, 10:27:31 pm
« Reply #6 on: December 25, 2011, 10:27:31 pm »
i only go down on autotragic... rest go up...
to go down the exhaust system down pipe needs popped out the way.. up no issue.. same for things like axles.. but i remove them too.. but someone lacking a 30mm axle nut socket helps them..
Reply #7December 26, 2011, 05:14:53 am
rs899
  • 647
« Reply #7 on: December 26, 2011, 05:14:53 am »
Well if I am going to have to pickup the car with the hoist I might do this ( which I have done in junkyards before).
Disconnect the tie rods, brake hoses, unbolt the tops of the struts and the through bolt on the lower control arms.  Drop everything with the axles on.  Saves some under car work
Reply #8December 26, 2011, 07:34:59 am
« Reply #8 on: December 26, 2011, 07:34:59 am »
I've done it. Best way imo to pull it if you've got the space. Dropped it on the tire and slid it over. It was also -25c... I always pick the coldest days to do stuff.. lol
I did lift it really sketchy though... LMAO  :o :o :o
Reply #9December 26, 2011, 08:02:07 am
DieselBalz
  • 301
« Reply #9 on: December 26, 2011, 08:02:07 am »
EWWWWwwwwww FRAM Oil Filter! GASP!
Reply #10December 26, 2011, 08:03:10 am
« Reply #10 on: December 26, 2011, 08:03:10 am »
I don't use em anymore. 5 years no problem then I had one fail.. Only MANN now.
Reply #11December 26, 2011, 08:05:50 am
DieselBalz
  • 301
« Reply #11 on: December 26, 2011, 08:05:50 am »
Haha just givin ya a hard time, same here Mann. Which reminds me, I have to order some more...
Reply #12January 03, 2012, 12:37:17 pm
veector
  • 95
« Reply #12 on: January 03, 2012, 12:37:17 pm »
Sorry slightly off topic, but -25C for a swap! wow I thought it sucked installing my advance cable today in -17C
On topic, Like the other said, best way I found is out the bottom, make sure engine and tranny are together when removing and installing.
1981 Jetta D
1997 Jetta TD
Reply #13January 03, 2012, 12:43:04 pm
« Reply #13 on: January 03, 2012, 12:43:04 pm »
as was stated already, the mk1 comes out the bottom, and the mk2 comes out the top..
i have an electric hoist in my shop, its amazing for pulling/dropping engines and trannies 8)
Reply #14January 06, 2012, 06:21:55 am
rs899
  • 647
« Reply #14 on: January 06, 2012, 06:21:55 am »
The car is up in the air on jackstands, the bolts have all been anointed with Pblaster...but SWMBO came home.  My priorities have been rearranged to fix a loose steering coupler on her ride ( 380SL Benz ). I have been at that 3 days...you can't imagine some of the access problems on that car... >:(
http://www.benzworld.org/forums/r-c107-sl-slc-class/1504056-steering-coupler-replacement-380sl-without-removing.html
It also doesn't help that SWMBO doesn't consider the Rabbit a "car"
« Last Edit: January 06, 2012, 06:25:49 am by rs899 »
