Author Topic: Misc MK1 and Audi stuff  (Read 5995 times)
December 17, 2011, 06:10:31 pm
rabbid79
  • 684
« on: December 17, 2011, 06:10:31 pm »
Hey guys, lots of misc. stuff for sale.  Prices don't include shipping.  Feel free to wheel and deal on multiple items.  I hate shipping lots of little things, so the more stuff I can put in one box, the happier I'll be.
New VW belts - some are genuine VW, some are not - I don't rememer the applications so you may need to look up the part numbers - I think the timing belt is for a 1.5D - $10 ea.
Fuel filter water sensor - includes fuel filter (pretty old though) - $20
MK1 plastic shock sleeves - $10 ea. pair
MK1 two gauge holder - goes under regular console - Like new - $25
BOV plug with V-band clamp - $25
New oil filter housing gasket for 1.9 - $5
Main bearing cap bolts from a new AAB diesel engine - Don't know if they're 1-time use or not - If they can be used - $10
Metal coolant line for '79 MK1 rabbit diesel - has some corrosion on the inside, but doesn't leak - $25
Now some Audi stuff:
Coolant hose for back of block on T44 Audi - $10
7A oil pan w/o extension, includes plastic baffle - has some pitting for corrosion around the front - fins are perfect - $75
AAN oil pan - $75
Brand new genuine Audi oil pickup tube baffle - $15
Brand new genuine Audi T43 coolant reservoir - Same as T44, but doesn't have provision for level sensor - $20
T43 turbo diesel air filter box plus hose - $25
T43 turbo diesel + VW turbo diesel blow off valve - $15
T43 turbo diesel turbo-to-intake manifold tube - $15
7A/NF flywheel - was machined prior to installation, but still has some hot spots - two timing pins were also shaved off - has new genuine Audi pilot bearing with only 8000 miles on it too, so you shouldn't need to replace it - $75
Spec stage 2 CQ pressure plate and clutch disc (SA232) with about 8000 miles - Pressure plate has a broken strap, but Spec offered to repair it - includes new release bearing and pilot bearing - $75 (You'll have to send it to Spec yourself - I can give you the RMA#)
'15 WRX
Reply #1January 02, 2012, 09:18:29 pm
rabbid79
  • 684
Re: Misc MK1 and Audi stuff
« Reply #1 on: January 02, 2012, 09:18:29 pm »
Bump.  Oil pans sold, oil pickup baffle and water indicator kit no longer FS.  Nobody even wants the machined BOV plug?  Shoot me an offer on this stuff guys.
'15 WRX
Reply #2January 15, 2012, 10:30:44 am
somedumbjerk
  • 71
« Reply #2 on: January 15, 2012, 10:30:44 am »
how much shipped to 94301 for the BOV plug?
Reply #3January 15, 2012, 01:03:40 pm
rabbid79
  • 684
« Reply #3 on: January 15, 2012, 01:03:40 pm »
How about $30?
'15 WRX
Reply #4January 15, 2012, 03:38:04 pm
somedumbjerk
  • 71
« Reply #4 on: January 15, 2012, 03:38:04 pm »
ok, what's your payapl?
Reply #5January 15, 2012, 05:57:52 pm
rabbid79
  • 684
« Reply #5 on: January 15, 2012, 05:57:52 pm »
PM sent.
'15 WRX
Reply #6January 15, 2012, 06:46:42 pm
rabbid79
  • 684
« Reply #6 on: January 15, 2012, 06:46:42 pm »
Example of what gauge holder looks like installed:
'15 WRX
Reply #7January 16, 2012, 04:47:29 pm
somedumbjerk
  • 71
« Reply #7 on: January 16, 2012, 04:47:29 pm »
money sent ;D
Reply #8January 16, 2012, 09:39:41 pm
rabbid79
  • 684
« Reply #8 on: January 16, 2012, 09:39:41 pm »
Thanks.  I'll try to get it out on Wednesday.
'15 WRX
Reply #9January 21, 2012, 01:07:12 pm
somedumbjerk
  • 71
« Reply #9 on: January 21, 2012, 01:07:12 pm »
got it! thanks!
