Author Topic: Serp alt  (Read 6523 times)
December 17, 2011, 01:31:34 pm
Serp alt
« on: December 17, 2011, 01:31:34 pm »
I have the big serp alt that I need to put on the car someday. It has the D+ and W terminals in a small plastic piece. It looks like it has a connector that is supposed to be on the car to plug in nice and neat. I have an 86 and no such connector. Does anyone know of a parts store that sells this or what it is even called to start looking for?
EDIT: it also has the B+ but that is a big stud that just needs a ring terminal and nut, I am good there.
Reply #1December 17, 2011, 01:41:13 pm
Re: Serp alt
« Reply #1 on: December 17, 2011, 01:41:13 pm »
its probably just some weather tight connector..
start looking under the hoods of imports till you find the right plug, and then snip it off.
Reply #2December 17, 2011, 02:22:15 pm
Re: Serp alt
« Reply #2 on: December 17, 2011, 02:22:15 pm »
That is for a bosch fuel injector and looks like it will fit. I would agree with you Kevin, but finding an import JY within an hour of me is not easy. All american boys around here, myself included, other than my VW addiction I got all amercian stuff. So JY isn't an option. I was hoping for a part # and then I could see if an old taurus or something had it.
Reply #3December 17, 2011, 04:33:51 pm
Re: Serp alt
« Reply #3 on: December 17, 2011, 04:33:51 pm »
Is it a VW alternator? I'd be willing to look around locally for you Lucas. Lotta VW love in my area.
Reply #4December 17, 2011, 05:10:24 pm
Re: Serp alt
« Reply #4 on: December 17, 2011, 05:10:24 pm »
In my relentless search I found this site: http://www.rangerovers.net/rrupgrades/electrical/boschalternator.html
It says that the thing I was looking at will work about 3/4 way down.  "This is a W and D+ plug, its a standard Bosch engine sensor/ fuel injector plug.
A simple plug to find at any auto parts store."
So basically if I find one fitting this discription: Fuel Injector Pigtail - Bosch EV1 Ford GM BMW Applications
I should be in there like swim wear. I can find tons of Ford stuff at the local JY, but for this I might see if it is a 5.00 and under part at napa.
Reply #5December 17, 2011, 10:57:58 pm
Re: Serp alt
« Reply #5 on: December 17, 2011, 10:57:58 pm »
me be the prick.. not that simple..
unlike a injector that can be plugged in in either direction.. it has plastic casting on the part you have.. to prevent mixing it up..
i think it has 2 at that.. not a single down the middle.. so you need to look at it.. i kept that harness for the tdi swap stuff i had due to not being a simple misc plug..  but due to how its stored in the corner its in i cannot even see it... shoot me over a pic of the plug on the alt.. or post it up.. im thinking its the same as the 02a back up light switch.. may be wrong.. but i have pieces of a ce2 harness left.. so may have a plug that will work..
and no non vw/audi would use that style plug.. gm/ford/dodge/toyota/honda/nissan do not use those bosh plugs.. they have their own crappy plastic ones..
if all else fails.. the small speaker terminals will work..
Reply #6December 18, 2011, 05:53:34 am
Re: Serp alt
« Reply #6 on: December 18, 2011, 05:53:34 am »
Just did more looking, a Bosch EV1 low profile should work if the regular one doesn't. I am in pretty good with the parts store guy, so I will just bring in the alt and see what fits.
This is ripped off pic don't mind the red arrows, but the plastic injection molded piece at the top is exactly like mine. The piece with the w term and the D+ in it.
Reply #7December 18, 2011, 09:22:03 am
Re: Serp alt
« Reply #7 on: December 18, 2011, 09:22:03 am »
Reply #8December 18, 2011, 01:55:01 pm
carrizog60
  • 978
Re: Serp alt
« Reply #8 on: December 18, 2011, 01:55:01 pm »
what are you going to do to tension the belt?
you need to swap the alternator suport and tensioner right?
i have the same problem as you but with this alternator:
Portugal
Reply #9December 18, 2011, 03:19:20 pm
Re: Serp alt
« Reply #9 on: December 18, 2011, 03:19:20 pm »
an injector connector off a mid 80s toyota of some sort will get you fixed up..
ive got a couple spare toyota wiring harnesses that i pull plugs off of :)
Reply #10December 22, 2011, 08:24:37 am
BigVWman
  • 332
Re: Serp alt
« Reply #10 on: December 22, 2011, 08:24:37 am »
carrizog60 if you can find a pick and pull or similar the plug you need came on an mk4 jetta or similar
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #11December 22, 2011, 05:26:57 pm
Re: Serp alt
« Reply #11 on: December 22, 2011, 05:26:57 pm »
BTW I went to napa...before the car killed itself...I took the alt and asked for a pigtail for it. They had nothing. I asked for an injector for a 90 1.8 vw gas, they stocked it and brought it out and fit like a glove.
Yes Carrizog, you need to swap the alt braket to one from an aaz or similar engine that came with the alt originally. Also, a clutched alt pulley and TDI crank sproket are encouraged too.
So the bosch EV1 style injector plug fits the Bosch serp alt.
« Last Edit: December 22, 2011, 05:28:29 pm by theman53 »
Reply #12December 23, 2011, 05:13:17 am
carrizog60
  • 978
Re: Serp alt
« Reply #12 on: December 23, 2011, 05:13:17 am »
i had a aaz and it uses the non tensioning serpentine belt.
the alternator moves to tension it like old TDīs.
clutched pulley i already have
Portugal
Reply #13December 23, 2011, 05:34:55 am
Re: Serp alt
« Reply #13 on: December 23, 2011, 05:34:55 am »
I haven't seen one of those. I was assuming all aaz had the serp setup.
