Author Topic: highest HP on vw idi achieved so far?  (Read 60687 times)
Reply #75September 10, 2012, 04:54:05 pm
  • 5104
Re: highest HP on vw idi achieved so far?
« Reply #75 on: September 10, 2012, 04:54:05 pm »
wow don't leave us hanging... what turbo and pump???
Turbo: Holset HE211W turbo with a 5cm^2 exhaust housing (the smaller brother of the more known HE221W)
Pump: 11mm superpump built by Dieselmeken in Sweden
do you know anymore about the turbo?  i saw it listed on holsets website but i couldn't find any information about it other than that it exists. inducer and exducer sizes would be nice.  it's sweet that the 5cm can flow that much power!  i wonder if the larger pump heads are needed to help make good power below 4000rpms, it would make sense sbecause most tdi's make their power in that range and tdi people have said the hp limit of the 10mm pump is 150hp or so i believe.  although idi's have proven the real limit is well over 200whp, but obviously at a much higher rpm.  anyways that car must haul ass geez leave it to the scandinavians to know how to build fast small displacements diesels when they live in such a cool region where you'd think no one would even drive a diesel haha
Reply #76September 10, 2012, 10:51:13 pm
Alcaid
  • 549
« Reply #76 on: September 10, 2012, 10:51:13 pm »
I've measured the wheels with a digital vernier myself, so numbers are not 100% accurate:
Compressor:
Exducer 56,0mm
Inducer 40,6mm
Trim 0.53
Turbine:
Inducer 46.6mm
Exducer 41.3mm
Trim 0.79
And a compressor map off course ;) I converted the mass axis to the more common lb/min:
Pretty close to surge on a stock 1.6TD head, but easily solved by slacking off the preload on the wastegate somewhat (1 round on the adjusting nut). On the 1.9D/TD heads there is no sign of surge what so ever.
'03 VW Golf PD130 4Motion Highline
'10 VW Passat 1.6TDI Highline
'83 VW Jetta 1.6TD, 11mm pump, H-beam rods, girdle, fully reworked AAZ head +++ Going Compound ;)
Reply #77September 11, 2012, 08:52:01 am
  • 5104
« Reply #77 on: September 11, 2012, 08:52:01 am »
Monday at 4pm. I'm set up to run at Horse Power Freaks shop. They use a Dyno Dynamics dyno. So I'll report back with the numbers.
Wish me luck.
On a side note: I got the truck all washed up and some what presentable, as HPF usually play with big dollar vehicles.
I figured out what the nitrous jet equivalency in horse power is. I'm using a .042 jet which = 73-75 HP.
I also dialed in the Dyno Tune Progressive controller. Wow!!! It launches so much better now. I launch at 4K RPM! I'm sure the trap speed time and ET is way better.
For some reason I had it tuned on the conservative side. With a starting % of .05 and total time to 100% at 2.5 sec. Now its a starting % of .10 and a total time to 100% at 1.8 sec. RPM is set to start 2400.
Man, That made all the difference. I gotta check if theres late night drags for this weekend. If so, I'm going!
results?????
Reply #78September 11, 2012, 08:58:41 am
  • 5104
« Reply #78 on: September 11, 2012, 08:58:41 am »
Compressor:
Exducer 56,0mm
Inducer 40,6mm
Trim 0.53
Turbine:
Inducer 46.6mm
Exducer 41.3mm
Trim 0.79
very good! where do you get these maps haha?  It is interesting this turbo is similar in size to the gt2056/gt2256 alot of people are running
Reply #79September 11, 2012, 11:00:16 am
Alleslowbuged
  • 270
« Reply #79 on: September 11, 2012, 11:00:16 am »
Hi,
if you have the map also available with "kg/s" axis i would be very glad if you could post that also.
Best Regards
By the way i like this thread
VW Golf Mk1 (Typ 17) 1981 with 1.6 TD
BMW E28 524 TD
Reply #80September 11, 2012, 03:02:59 pm
« Reply #80 on: September 11, 2012, 03:02:59 pm »
DAMN!! josh didnt post up the dyno sheet yet!!
he called me and told me all about it..
but im not gonna spoil it for everyone!
gotta wait till josh gets around to scanning/posting the dyno graph..
and we all know how busy josh is!!
Reply #81September 11, 2012, 03:13:42 pm
  • 5104
« Reply #81 on: September 11, 2012, 03:13:42 pm »
Today I just wish I still had his number haha
Reply #82September 11, 2012, 04:24:58 pm
  • 5104
« Reply #82 on: September 11, 2012, 04:24:58 pm »
Tell josh to forget about is wife and kids and report to us
Reply #83September 11, 2012, 06:57:43 pm
  • 5104
« Reply #83 on: September 11, 2012, 06:57:43 pm »
i think we have concluded, that joshes truck was infact a hoax from the beginning, from what i heard he is actually a nigerian who photoshopped the pictures in an internet cafe.
Reply #84September 11, 2012, 07:08:23 pm
« Reply #84 on: September 11, 2012, 07:08:23 pm »
LOL
Reply #85September 11, 2012, 07:09:07 pm
« Reply #85 on: September 11, 2012, 07:09:07 pm »
Thought it was only rumors.. lol!
Reply #86September 11, 2012, 08:29:11 pm
Powered by Spearco
  • 1203
« Reply #86 on: September 11, 2012, 08:29:11 pm »
/quote]
Thats funny!  ;D
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #87September 11, 2012, 09:11:37 pm
Powered by Spearco
  • 1203
« Reply #87 on: September 11, 2012, 09:11:37 pm »
So here is the results of a few pulls on the dyno.
First and foremost, I was not satisfied with the operators at HPF. Due to how they loaded my truck up on the dyno, all jacked up and crooked, how they strapped it down, loose, how they attempted to set up their optic sensor for RPM signal and the whole operation of the dyno, unexperienced with old school diesels. They're used to OBD2 ports. The operator let it compression brake from 6K RPM!!!
Also, after playing with the nitrous tuner on Sunday, I must have ran out of nitrous half way through a pull on the dyno,  cuz it just didn't  feel right. Not that i have excuses for the results but there is some issues with the way it was set up and I ran out of NO2.
This is with stock waste gate 11psi.
This is is what I thought was 28psi.
Here is the nitrous and what was thought to be 24psi.
So there you have it.  ::) It is  a hoax!  :P.
I plan to refill the bottle and try again, check my boost gauge for accuracy and test with the G-Tec.
'13 Golf R:. Tuned
'98 Puch G320
Reply #88September 11, 2012, 09:22:59 pm
« Reply #88 on: September 11, 2012, 09:22:59 pm »
You got my 2.5liter on  on HP, but not quite there with the torque yet:D
Reply #89September 11, 2012, 09:28:36 pm
Powered by Spearco
  • 1203
« Reply #89 on: September 11, 2012, 09:28:36 pm »
Wow. Really?
'13 Golf R:. Tuned
'98 Puch G320
