Author Topic: standard exhaust size?  (Read 4254 times)
December 10, 2011, 04:06:03 pm
Vohaul
  • 105
« on: December 10, 2011, 04:06:03 pm »
My stock exhaust has rusted out on the first muffler (least i think thats what it is)..(the smaller muffler in front of the rear axle)...Seeing as its close to xmas and im already poor:) ...i am just thinking of getting a replacement piece of bendable pipe..and some u bolt clamps to effect a repair until i can take it in for a whole new exhaust. after xmas...
My plan is to cut out the first muffler and replace it with the bendy pipe (you know the pieces with the steel braided like section in the middle you can get from can tire....)...
Can someone tell me what size / diameter the stock pipe is on a 94' AAZ 1.9 turbodiesel jetta....
Thanks
Paul
Reply #1December 10, 2011, 07:18:36 pm
Re: standard exhaust size?
« Reply #1 on: December 10, 2011, 07:18:36 pm »
1 3/4"? A measuring tape would tell you for sure what your car has, as it could have been changed since 1994..
Reply #2December 11, 2011, 12:40:27 pm
« Reply #2 on: December 11, 2011, 12:40:27 pm »
Measure the circumference all the way around (use a piece of string and measure the length) and divide by 3.14, that should give you a close approximation for the outside diameter, then go find a pipe that has that as the inside diameter, to slip over the end of your exhaust pipe where you cut it.
Reply #3December 11, 2011, 06:33:36 pm
Vohaul
  • 105
« Reply #3 on: December 11, 2011, 06:33:36 pm »
ase anyone wanted to know, its 1 7/8ths......
and that "1st muffler" i cut out is a cat...i think...i didnt know a 94 diesel would even have one:)\
but its all fixed ahh...sweet silence..well, as much sweet silence as a diesel can manage...
Reply #4December 16, 2011, 07:05:04 pm
Grey_Smoke
  • 83
    fling wing for the win.
« Reply #4 on: December 16, 2011, 07:05:04 pm »
It may be a cat, but iirc it should be a resonator, I think most of them came with one.
2001 TDI
86 Jetta Coupe TD - Still going together
sold - the Gutless wonder - 97 AAZ
An Oldvolks Home
Reply #5December 18, 2011, 11:53:51 am
« Reply #5 on: December 18, 2011, 11:53:51 am »
The AAZ cars all had a cat.  Mine rotted out last year, which at least let me to getting my exhaust upgraded.
