Author Topic: WTB 1.6TD metal injector lines, and maybe used injector set  (Read 4111 times)
December 05, 2011, 05:37:53 pm
purvisgs
  • 45
« on: December 05, 2011, 05:37:53 pm »
Looking for metal injection lines from 1.6 turbo jetta, IP to engine, or if you think you can bend YOUR set of 1.6NA lines to make them work, I would buy those.  Offer to pay around $40, shipped... maybe A LITTLE more if you can throw in some used injectors.  ...If you have a set of used 1.6td injectors in usable (don't have to have been spray tested, just from engine that was running) shape that you would consider selling cheap I'm interested!  But would prefer to buy both from the same person, or just the metal lines.  Email purvisgs(at)yahoo (dot) com.  Thanks!
Reply #1December 09, 2011, 08:09:57 am
Re: WTB 1.6TD metal injector lines, and maybe used injector set
« Reply #1 on: December 09, 2011, 08:09:57 am »
Where are you located? I have several sets of lines, and injectors all from running motors :)
Reply #2December 09, 2011, 09:30:44 am
« Reply #2 on: December 09, 2011, 09:30:44 am »
IMO 40 is pretty lowball..when each line is valued by the stealership at over $100.. only #1 and 2 are td specific.. 3-4 same as na.. i think you need to add a few more dolla to your offer..
td injectors also different pop value then na ones.. so again value goes up..
do not forget.. you will need new heatshields that injectors sit on if you replace the injectors..
Reply #3December 09, 2011, 02:47:30 pm
« Reply #3 on: December 09, 2011, 02:47:30 pm »
https://www.autohausaz.com/search/product.aspx?sid=qb3rc3npozsfr3bmkbp5rn45&makeid=800026@VW&modelid=1282845@JETTA DELUXE &year=1986&cid=22@Fuel %26 Air System&gid=11220@Fuel Injector Line
NA ^
http://www.ebay.com/itm/VW-Rabbit-Mk1-Golf-Caddy-Turbo-Diesel-Injector-Line-Kit-/220377265104?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item334f8233d0
TD^
Those are new and more than you wanted to pay, but fair as this world of parts are. You wouldn't have to worry about quality issues with them though.
Reply #4December 09, 2011, 02:53:16 pm
« Reply #4 on: December 09, 2011, 02:53:16 pm »
I still got a few sets of injectors you can have if you wish.
