Author Topic: WTB: Fitting to attach to 1.6td injection pump so I can measure pressure?  (Read 4225 times)
December 02, 2011, 06:39:59 pm
damac
  • 531
I have no spare parts.  So I would like to either rent from somebody or buy a fitting that I can hook up to the 1.6td injection pump in my 85 jetta td so I can check out the pump pressure.
1985 turbo diesel jetta
Reply #1December 03, 2011, 07:33:22 pm
Re: WTB: Fitting to attach to 1.6td injection pump so I can measure pressure?
« Reply #1 on: December 03, 2011, 07:33:22 pm »
If no one comes up with one for you soon I still have an extra bolt, some nuts and a banjo fitting I think and I could fab one up for you next weekend.  I will check back Friday on this.
Reply #2December 03, 2011, 08:55:04 pm
« Reply #2 on: December 03, 2011, 08:55:04 pm »
ill show my newbish... got a pic of this thing?? id like to see how and what is being used to measure the pressure..
Reply #3December 04, 2011, 06:52:05 am
Reply #4December 04, 2011, 06:46:08 pm
« Reply #4 on: December 04, 2011, 06:46:08 pm »
This is what I rigged up.  Bolt on the bottom drilled out the top surface and soldered a nut on that.  Banjo on the bottom goes to line and fittings and then the gauge.  Top Banjo is the normal one with the restriction and the two different sized ports for the injector return and tank return.
Pretty simple, threaded the line with others through the dash to gauges on a salvaged center column out of a GTI I think it was.  Room for five gauges.
« Last Edit: December 04, 2011, 06:51:04 pm by ORCoaster »
Reply #5December 08, 2011, 08:51:43 pm
« Reply #5 on: December 08, 2011, 08:51:43 pm »
Damac, still need this or did ya build yer own?
Reply #6December 09, 2011, 07:04:33 pm
damac
  • 531
« Reply #6 on: December 09, 2011, 07:04:33 pm »
I never got one and still figured it would be a good thing to have in the tool drawer even though my car runs ok right now?
