Author Topic: My starter groans sometimes  (Read 3802 times)
December 02, 2011, 12:23:10 pm
« on: December 02, 2011, 12:23:10 pm »
In the MK2 golf, usually does it when it's working extra hard like if the engines cold. I replaced the shaft bushing but it didn't fix it.
FWIW this is a gear reduction starter with all the little planetaries. It seems weak too, especially when it starts groaning.
Reply #1December 02, 2011, 06:51:52 pm
Re: My starter groans sometimes
« Reply #1 on: December 02, 2011, 06:51:52 pm »
Do you have good cables going to it? The ground right under one of the mounting bolts?
Reply #2December 02, 2011, 08:07:25 pm
« Reply #2 on: December 02, 2011, 08:07:25 pm »
Yup I have big fat cables on it, idk what gauge they are but they're probably half inch diameter.
The ground is under one of the big bell housing bolts which I figured would be as good as under a starter bolt.
I bought a new battery today and it cranked waaaay faster and longer than before but it still makes that weird groaning sound sometimes.
