Author Topic: M-TDI 10mm pump  (Read 4945 times)
December 01, 2011, 11:00:35 am
Tintin
  • 1279
M-TDI 10mm pump
« on: December 01, 2011, 11:00:35 am »
For sale an M-TDI pump 10mm head, 20mm main shaft. The housing have the slotted mounting hole to use with an AHU pulley if wanted.
I want sold$
« Last Edit: December 06, 2011, 09:35:27 pm by Tintin »
Reply #1December 01, 2011, 03:13:55 pm
vegged-out
  • 40
Re: M-TDI 10mm pump
« Reply #1 on: December 01, 2011, 03:13:55 pm »
HI Tintin
I am intereted in buying the pump. can you confirm source of parts? is pump body from aaz or 4bt? is rotor new? bosch or asian? governor mods?
thanks
Michiel
Reply #2December 01, 2011, 03:25:45 pm
Re: M-TDI 10mm pump
« Reply #2 on: December 01, 2011, 03:25:45 pm »
HI Tintin
thanks
Michiel
i can tell you its a LEGIT pump coming from Tin-Tin..
nothing chinese in there.. all bosch parts for sure.
im gonna say its in a 1.6, or AAZ case..
Reply #3December 01, 2011, 03:28:08 pm
Re: M-TDI 10mm pump
« Reply #3 on: December 01, 2011, 03:28:08 pm »
it's à good m-tdi pump!!
You can the bought blindly
Reply #4December 01, 2011, 03:32:31 pm
vegged-out
  • 40
Re: M-TDI 10mm pump
« Reply #4 on: December 01, 2011, 03:32:31 pm »
OK you've convinced me. I'll buy it. Pmail sent.
Michiel
Reply #5December 06, 2011, 09:33:52 pm
Tintin
  • 1279
Re: M-TDI 10mm pump
« Reply #5 on: December 06, 2011, 09:33:52 pm »
Pump is sold to Michiel last week.
And yep, it's only Bosch parts, second hand but in good condition, it's by far better than even brand new chinese, a junk cam-plate last for about 1000 to 2000km and it's shot, compared to a Bosch one that can last for 700,000km +.
Now that I can work with ECU, it's much more easier to compare pumps parts performance, I found many times that even a 300,000km + Bosch 10mm rotor head can outfuel a brand new 11mm chinese head.
Other parts are home made/modified Bosch to keep the cost down, there is no other choice, I can use unmodified parts if wanted, but the price will be in the 3 digits.
Seal kit is Bosch, and new of course.
Reply #6December 25, 2011, 08:54:16 pm
32 VALVES
Re: M-TDI 10mm pump
« Reply #6 on: December 25, 2011, 08:54:16 pm »
what would it cost for you to reseal my pump and juice it up some?
