Author Topic: anyone got a starter?  (Read 8495 times)
Reply #15November 22, 2011, 05:40:32 am
jimbote
  • 168
Re: anyone got a starter?
« Reply #15 on: November 22, 2011, 05:40:32 am »
the "real" way to go is the MKIV TDI 01M automatic starter...it's gear reduction and 2KW ...and if you add the thick MKIV TDI starter cables (power and ground) you have an unbeatable combination....I ran this setup on my 1.6td caddy and it spun over fast enough to skip the glows!!
Reply #16November 22, 2011, 12:33:41 pm
damac
  • 531
« Reply #16 on: November 22, 2011, 12:33:41 pm »
any mods needed to bolt it up?
used with stock battery and it spun ok?
1985 turbo diesel jetta
Reply #17November 22, 2011, 10:02:34 pm
jimbote
  • 168
« Reply #17 on: November 22, 2011, 10:02:34 pm »
it bolts right up...no mods and yes a stock battery and cables work fine...another plus is you don't need the small bushing in the trans ...the starter bendix shaft is self supporting
Reply #18December 03, 2011, 02:05:25 pm
wdkingery
  • 494
« Reply #18 on: December 03, 2011, 02:05:25 pm »
Had 2 of 4 brushes left on my starter.. Hung a gasser starter.. :-( works good (for now) tho
Reply #19December 03, 2011, 05:44:09 pm
« Reply #19 on: December 03, 2011, 05:44:09 pm »
your diesel dont have much compression then, usually a gasser starter struggles to start a diesel..
Reply #20December 03, 2011, 07:06:56 pm
« Reply #20 on: December 03, 2011, 07:06:56 pm »
A healthy gas starter shouldn't have issues starting a diesel if it's not too cold out.
Reply #21December 05, 2011, 07:31:33 pm
« Reply #21 on: December 05, 2011, 07:31:33 pm »
That's probably right, tried one and it only worked if the engine was hot otherwise it needed to crank faster than the gasser starter could do it.
Reply #22December 06, 2011, 03:07:52 pm
« Reply #22 on: December 06, 2011, 03:07:52 pm »
i had the same results..
Reply #23December 06, 2011, 09:49:18 pm
wdkingery
  • 494
« Reply #23 on: December 06, 2011, 09:49:18 pm »
This little thing is working like a champ.. Hasn't been cold yet tho. But it's.. Workin too well. My motor must be tired lol
Or maybe it's that sweet f250 mod!
« Last Edit: December 07, 2011, 07:22:07 am by wdkingery »
Reply #24December 08, 2011, 07:43:37 am
« Reply #24 on: December 08, 2011, 07:43:37 am »
that F250 mod would be overcome by ONE GOOD 1000cca battery..
