General Information
Upgrades (non engine related )
80% kitb
Topic: 80% kitb (Read 4235 times)
February 03, 2006, 11:04:09 pm
hillfolk'r
80% kitb
February 03, 2006, 11:04:09 pm »
hey,anyone else runnin one of those peloquin 80percent kits,, they say not to use them w/ 90 mm flanges,but i called them direct and theysaid "as long as its not really lowered",,so i got stock ride height,,am i gonna be ok for tomorrows(oops today i guess) startup ,and test drive??yummy
,,,,,oh the trans is an ol 020 code 7a in a old rabbit,,,man deo,,now you got me allworried ill have no power ,till i get the delivery valves right,,,,whynot get some out an old tdi pump??
Throttle cables ftw
February 08, 2006, 07:37:15 am
fspGTD
80% kitb
February 08, 2006, 07:37:15 am »
I've used the peloquin 80% kits before. If your 020 transmission has a green painted tin-metal seal carrier for its passenger side output shaft, it has the factory "mini-slip" stuff inside, which can be upgraded to the peloquin 80% kit. You'll typically only see transmissions that come on sometimes '84 and probably most or all 1985 or newer models. Gary (Peloquin) has always answered the phone directly whenever I've called there and has been very helpful, I would give him a call if there is any question about your transmission. Hope this helps - good luck!
Jake Russell
Dieselicious
Turbocharger Upgrade/Rebuild Kits
February 09, 2006, 08:24:31 pm
euronation
Newbie
80% kitb
February 09, 2006, 08:24:31 pm »
Gary Peloquin is a great guy. I actually get Christmas cards from those guys.
The issue with 90mm flanges and lowered cars comes with the axle shaft butting up against the locking bolt. 100mm flanges have a bit more depth. If you have and issues with breaking CVs (resulting from the axle butting against the locking bolt) you can cheat your way to a 40% kit by removing the machined cap and bolt and simply replacing them with the factory thrust washer and spring clip.
-Aaron
www.euronationmotorsport.com
February 10, 2006, 10:41:19 am
hillfolk'r
80% kitb
February 10, 2006, 10:41:19 am »
im alreadyusing the 80% kit ,,, i like it,,havent heard any funny noises yet,,yea i ordered it direct from gary,,,great guy,,i dont plan onlowering it,,,,so i guess ill be ok,,,
Throttle cables ftw
General Information
80% kitb
