Author Topic: Quick weatherstrip alternative question  (Read 3875 times)
November 10, 2011, 04:12:06 pm
camboscams
  • 324
« on: November 10, 2011, 04:12:06 pm »
So would something like this work in our MK1's. I can't find anything to replace whats there but im wondering if this would work on the car side right on the pinch welded opening.
Just search this number 1120A391 on Mcmaster.com
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #1November 10, 2011, 04:23:43 pm
camboscams
  • 324
Re: Quick weatherstrip alternative question
« Reply #1 on: November 10, 2011, 04:23:43 pm »
The bulb would face outwards. but the more i look at it maybe the bulb should be a little bit bigger.
Reply #2November 10, 2011, 07:18:11 pm
rabbitman
  • 2788
« Reply #2 on: November 10, 2011, 07:18:11 pm »
Mounted on the car side I'm not sure what part of the door would seal on it.......I'd really like to have new seals too.
Reply #3November 10, 2011, 07:32:44 pm
camboscams
  • 324
« Reply #3 on: November 10, 2011, 07:32:44 pm »
So where the factory edge grip seal is over the pinch weld in the door opening on the body of the car. The black stuff on each side of where the upper mounting point for the seatbelt. It would seal on the inner facing side of the door.
Reply #4November 12, 2011, 04:37:18 pm
GEE-BEE
  • 1604
« Reply #4 on: November 12, 2011, 04:37:18 pm »
Iam running 5000 ft of upper door seal
original mk1 design
GB
[email protected]
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #5November 13, 2011, 05:52:31 am
camboscams
  • 324
« Reply #5 on: November 13, 2011, 05:52:31 am »
So your making weather strip that is right above the window where it seals on the body? just the short section on the horizontal part of the door?
Reply #6November 13, 2011, 07:50:31 am
GEE-BEE
  • 1604
« Reply #6 on: November 13, 2011, 07:50:31 am »
you are correct from the original design
I make all the seals for MK1autohaus & silicone hoses for the mk1 & mkII
Vanagon diesel and synros for vancafe
GB
Giles Pump OHC
MK1 JETTA DASH
