Author Topic: Front strut on a jetta Mk1 83  (Read 3678 times)
November 02, 2011, 10:24:44 am
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« on: November 02, 2011, 10:24:44 am »
On the front strut on the jetta does the shock absorber come out of the strut like a cartage?
Or do i have to order the whole strut?
Thanks, Corey
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #1November 02, 2011, 10:54:20 am
Re: Front strut on a jetta Mk1 83
« Reply #1 on: November 02, 2011, 10:54:20 am »
i THINK that they made cars both ways, but i think most of them you just drop in a new cartridge..
Reply #2November 02, 2011, 04:16:29 pm
mystery3
  • 774
« Reply #2 on: November 02, 2011, 04:16:29 pm »
It all depends on whether you have the original struts, probably not so what have they been replaced with in the last 30 years?
Reply #3November 03, 2011, 10:14:19 pm
dankcorey22
  • 379
    Cummins!
« Reply #3 on: November 03, 2011, 10:14:19 pm »
I really do think mine are stock struts, The struts are welded to the so called cartridge or shock. And the only place i know who sells the whole strut is worldimpex.com and parts place which is crazy priced
Does anyone else know where to get them. Or whos running aftermarket brand struts
Reply #4November 03, 2011, 11:04:13 pm
mystery3
  • 774
« Reply #4 on: November 03, 2011, 11:04:13 pm »
Here are sachs at $56 each
http://www.partsgeek.com/catalog/1983/volkswagen/jetta/suspension/strut_assembly.html
How expensive and what brand were the others you found?
Reply #5November 04, 2011, 06:23:58 am
« Reply #5 on: November 04, 2011, 06:23:58 am »
PArt #  27A580  on RockAuto.com $52
Put your old spring and a new strut mount on and DONE!.
Reply #6November 04, 2011, 12:27:49 pm
dankcorey22
  • 379
    Cummins!
« Reply #6 on: November 04, 2011, 12:27:49 pm »
Thanks guys im going to order one of the two not decided yet.
Partsplaceinc.com was 349.00  ::)
And worldimpex.com was 75.00 for sachs
