For Sale/Looking For
Parts for Sale/Wanted
WTB crank pulley bolt and thick washer 1.6TD
Topic: WTB crank pulley bolt and thick washer 1.6TD (Read 4544 times)
October 24, 2011, 07:16:28 pm
vdub-son
Newbie
October 24, 2011, 07:16:28 pm »
Looking for a crank pulley bolt and thick washer for my 1.6TD
PM me if you have them as well as a price, location
Thinking it is best to use the stock ones, and the dealer says no longer available.
Or if anyone can suggest a proper alternative? Not sure if a grade 8 bolt without shoulder and just a std washer would be a good idea...
Thanks.
mk1s with 1.6 NA & TD
October 25, 2011, 02:50:11 am
ilikevwdiesel
Re: WTB crank pulley bolt and thick washer 1.6TD
October 25, 2011, 02:50:11 am »
http://www.gowestyautoparts.com/OEM/oemSearch.aspx?search=n90577101
Look, if corn and kudzu fall in love and have a baby in a lab under the supervision of scientists working in my employ, WHO AM I TO STOP THAT other than the CEO responsible for stopping it???
My Bio
November 04, 2011, 05:20:11 pm
vdub-son
Newbie
November 04, 2011, 05:20:11 pm »
Thanks for the tip - I ordered and received my new bolt!
November 04, 2011, 09:49:46 pm
November 04, 2011, 09:49:46 pm »
It might be shorter than the original bolt,.. and I don't think the fat washer will work with the 12-point bolt because it is shorter.
November 06, 2011, 09:55:28 am
vdub-son
Newbie
November 06, 2011, 09:55:28 am »
Indeed it is shorter, so I machined the washer to be a little thinner...
Anyone have experience running the crank bolt without the thick washer?
December 04, 2011, 10:40:16 pm
Jory
December 04, 2011, 10:40:16 pm »
That looks like the later-style stretch bolt. I don't believe you're supposed to use a washer with it.
December 05, 2011, 04:22:14 am
December 05, 2011, 04:22:14 am »
x2. You don't use the washer with that and the torque procedure is different than your old bolt. This is very important.
Round 2
December 05, 2011, 12:43:25 pm
vdub-son
Newbie
December 05, 2011, 12:43:25 pm »
Thanks for the info all!
Could you outline the procedure?
I have not re-assembled yet.
December 05, 2011, 02:05:59 pm
ilikevwdiesel
December 05, 2011, 02:05:59 pm »
lightly oil the bolt, install it into the pulley, thread it into the crank nose, tighten to 90 nm and 1/4 turn after that. a friend of mine made me this gizmo to lock up the engine during the final torque. bolt it to the pulley and turn the motor till it hits the ground. make sure you've got the timing belt on tho. :-)
Last Edit: December 05, 2011, 02:13:11 pm by ilikevwdiesel
My Bio
