Author Topic: Which 1.9 gasket for a 1.6?  (Read 2595 times)
October 10, 2011, 09:09:34 am
monomer
  • 414
« on: October 10, 2011, 09:09:34 am »
http://www.partsplaceinc.com/products/product-detail.aspx?keyword=VW+TDI+1+notch+cylinder+head+gasket+28-103-383&s=90&&sku=18629
Will this work in my 1.6D mechanical 1.6 head?
Are the "notches" the same? It has a one notch/factory fibre gasket in it right now. Pulling the head today, installing arp cosworth studs: might aswell go MLS as one day this things getting turbo.
Gonna be leaving shortly, parts place is just a small hike. Need to know!
www.michiganvw.org
Reply #1October 10, 2011, 09:18:16 am
Re: Which 1.9 gasket for a 1.6?
« Reply #1 on: October 10, 2011, 09:18:16 am »
its not a DIRECT fit.. but it can be used with a few small modifications..
Reply #2October 10, 2011, 09:21:13 am
monomer
  • 414
« Reply #2 on: October 10, 2011, 09:21:13 am »
I recall reading about plugging some oil galley hole or something, and seeing people put a gasket over it.
Are the notches the same for both? I don't want to get the wrong thickness.
www.michiganvw.org
Reply #3October 10, 2011, 09:27:48 am
« Reply #3 on: October 10, 2011, 09:27:48 am »
i think the notches are all the same for hydro motors, but im not positive..
Reply #4October 10, 2011, 09:31:44 am
monomer
  • 414
« Reply #4 on: October 10, 2011, 09:31:44 am »
It's a mechanical head, if I remember things correctly.
Pucks to set lash.
Is this going to be a problem? I just REALLY don't want to buy the wrong gasket....
www.michiganvw.org
Reply #5October 10, 2011, 10:39:58 am
MJF
  • 581
« Reply #5 on: October 10, 2011, 10:39:58 am »
Get TD gasket, not TDI
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #6October 10, 2011, 10:43:44 am
« Reply #6 on: October 10, 2011, 10:43:44 am »
oh, yea... GOTTA USE AN AAZ GASKET, not TDI..
TDI gasket is for direct injection, and has nowhere to seal to the pre cup..
i didnt look at the link first, just assumed it was linked to an AAZ gasket..
Reply #7October 10, 2011, 11:35:14 am
monomer
  • 414
« Reply #7 on: October 10, 2011, 11:35:14 am »
They didnt have aaz gaskets in stock.
Ended up with a normal mechanical fibre gasket.
I can never seem to get out of spending less then a c-note at that place....
www.michiganvw.org
