Author Topic: 88 VW Fox -9.4" Vented Rotors swap right in ?  (Read 13365 times)
September 19, 2011, 10:09:42 pm
2strokesmoke
« on: September 19, 2011, 10:09:42 pm »
Hi Guys,
I recently purchased an 88 VW fox wagon,from someone on the vortex.
Great guy- he installed a 1.6TD in this car.
Purchased the car as a "conversion in progress"
I need to replace front brakes and was wondering if I could swap in 9.4" vented rotors.
I did this swap on my 82 caddy and love it !
In fact-they look like the same rotors.
Does anyone know if the vented rotors fit? and if I need to use a different brake pads to make the rotors fit?
Thanks a bunch !
Mike
Reply #1September 20, 2011, 02:22:26 pm
vanagonturbo
  • 639
    • Fine Tuning
Re: 88 VW Fox -9.4" Vented Rotors swap right in ?
« Reply #1 on: September 20, 2011, 02:22:26 pm »
The rotors *should* fit. check the width of the rotor and compare it to the slot in the pad carrier and see if it fits. You will need thinner brake pads though. I have no idea where you would get those. Maybe someone that has used up 50% of their pads?
You might be better off swapping the brake from a QSW. Those are also 10.1"
Reply #2September 20, 2011, 02:34:54 pm
rabbitman
  • 2788
« Reply #2 on: September 20, 2011, 02:34:54 pm »
I did this swap on my '82 rabbit and '92 golf, the golf needed different calipers (wider) but it went easy after that. I would assume a fox would be the same, try looking up the part # for the caliper and see if it's the same as a MK2 golf/jetta.
Reply #3September 20, 2011, 03:08:24 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #3 on: September 20, 2011, 03:08:24 pm »
Which swap? the 10.1"?
Reply #4September 20, 2011, 03:31:44 pm
« Reply #4 on: September 20, 2011, 03:31:44 pm »
9.4 solid disks to vented disks..
10.1 requires different calipers and carriers. mk2 requires a different knuckle, and ball joints if its an 87 or older (caliper bracket integral to the hub, and 19mm ball joints, instead of 17mm balls)
« Last Edit: September 20, 2011, 03:54:26 pm by R.O.R-2.0 »
Reply #5September 20, 2011, 03:49:52 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #5 on: September 20, 2011, 03:49:52 pm »
I was asking in reference to what rabbitman was saying. The calipers do not need to be changed to go from non vented 9.4 to vented.
A MKI does not need the spindle changed to upgrade brake diameter and neither does the fox spindle (IIRC). Onl the MKII needs the spindle changed.
Reply #6September 20, 2011, 03:57:26 pm
« Reply #6 on: September 20, 2011, 03:57:26 pm »
i was replying for rabbitman, i remembered his swap. he DID have to change his calipers. they were not wide enough to fit the vented rotors. first person ive ever heard of having to change calipers. all my solid-2-vented swaps have all been straight forward, no other parts to change besides the rotor its self.. were probably mexican calipers or something. all the cars that ive swapped, had german brake parts.
and sorry about the mis-information.. in my head i was thinking about the mk2, just forgot to add that part into my post, but i fixed it. thanks for pointing that out tho..
Reply #7September 20, 2011, 04:02:37 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #7 on: September 20, 2011, 04:02:37 pm »
Wow, that is really strange. I have never heard of that. Is there a thread or something that he made about it? Pics maybe? Thats one for the database! :)
Reply #8September 21, 2011, 02:33:26 pm
rabbitman
  • 2788
« Reply #8 on: September 21, 2011, 02:33:26 pm »
http://www.vwdiesel.net/forum/index.php?topic=29755.0
Yup it was strange, with the piston squeezed back it was still a 3/16" too narrow to fit over the vented disk and proper skinny pads. I compared with other vdubs around here and sure enough, the whole caliper was narrower so I bought new ones off amazon and viola, they fit. This is a '92 german golf that was never meant for north america so lots of little things are different on it........like no rear seatbelts........
Reply #9September 21, 2011, 03:03:25 pm
« Reply #9 on: September 21, 2011, 03:03:25 pm »
i want your head lights..  8)
im never gonna be happy till i find that kind of setup..
Reply #10September 21, 2011, 03:11:20 pm
rabbitman
  • 2788
« Reply #10 on: September 21, 2011, 03:11:20 pm »
You mean the dual rounds? hehe yeah I like 'em too. I've always liked quad rounds better though.......except that that's what everyone upgrades to.
They even have the little motors to adjust beam height while driving. ;D
Reply #11September 21, 2011, 03:18:02 pm
« Reply #11 on: September 21, 2011, 03:18:02 pm »
thats why i want YOUR headlights. i about shat a buick when i saw that.. only pair ive ever seen.
i like dual crosshairs the best. quads are ok, but duals are my favorite.
Reply #12September 21, 2011, 04:57:16 pm
rabbitman
  • 2788
« Reply #12 on: September 21, 2011, 04:57:16 pm »
I saw a complete set of adjusters on ebay a couple years ago, motors, wiring harness, switch and all that for 400 bucks!!!!!! I never thought I'd end up with a set.........
Reply #13September 21, 2011, 05:29:44 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #13 on: September 21, 2011, 05:29:44 pm »
Wierd. Makes sense though. My German Golf came with rear seatbelts and mine is an 87. Maybe yours was supposed to be a delivery vehicle or something?
$400 seems pretty spendy for a headlight levelling system. You could probably get the whole setup for about €150. I got a headlgiht and a switch for €20. Just need another headlight, two motors and a bit of wiring now..
Reply #14September 21, 2011, 11:05:26 pm
2strokesmoke
« Reply #14 on: September 21, 2011, 11:05:26 pm »
Hi guys,
Thanks for your input !
So, we say the vented rotors should fit my 88 Fox wagon, with "stock" front pads ?
Or do I need front pads from another vehicle,to make them fit?
( for example: My 82 caddy needed 84 GTI pads to fit)
I'm purchasing 2 reman calipers and new hoses-for the Fox soon,so if I need to install something different,now is the time.
Thanks a bunch !
Mike
