Author Topic: 1.6 td down pipe  (Read 4995 times)
September 13, 2011, 04:23:38 pm
Dean Erickson
  • 58
1.6 td down pipe
« on: September 13, 2011, 04:23:38 pm »
Will a 1.6 td exhaust down pipe of a 1991 Jetta work on my 1981 Rabbit truck. I have heard there may be some clearence problems with the shift linkage. Can the pipe be mod. to work?
Reply #1September 13, 2011, 06:11:08 pm
Re: 1.6 td down pipe
« Reply #1 on: September 13, 2011, 06:11:08 pm »
not even CLOSE to fitting.. you would have to hack it up soo bad that it wouldnt even be worth it..
the steering rack is mounted to the BODY on your car..
the steering rack is mounted to the SUB FRAME on the mk2 car you want parts off of.
it clears the shift linkage just fine, just wont clear anything else  ;)
wait, turbo downpipe, or exhaust downpipe? there IS a difference.
turbo downpipe is cast iron, bolts directly to turbo.
exhaust downpipe is steel tubing, and connects to the turbo downpipe with some BIG c clips.
Reply #2September 13, 2011, 07:29:47 pm
  • 2932
« Reply #2 on: September 13, 2011, 07:29:47 pm »
Sometimes when they say downpipe they mean the ?-pipe coming out of the turbo.
 That will work, with some adjustments to the shift lever.
Reply #3September 13, 2011, 07:56:39 pm
« Reply #3 on: September 13, 2011, 07:56:39 pm »
yea, if you just want to use the cast iron piece, then its fine, it works, the actual downpipe does not tho.
Reply #4September 16, 2011, 06:34:55 pm
Dean Erickson
  • 58
« Reply #4 on: September 16, 2011, 06:34:55 pm »
Yes the cast iron part is what I was talking about. So it should work then, Thanks.
