Author Topic: 1.6td shift points  (Read 8040 times)
Reply #30September 15, 2011, 01:53:33 pm
Re: 1.6td shift points
« Reply #30 on: September 15, 2011, 01:53:33 pm »
unhook the LDA? iirc, the whole top just pops off and there was no difference in the bottom of the pumps between na and td.. but i could be wrong.
all i was stating, was that the pumps are identical with no boost applied..
Pretty sure that's right, the NA pump has a fixed stop pin inside while the TD pump has the "moveable stop" hanging down from the LDA. This has been gone over quite a bit 8).
EDIT: Not sure about how they look but IIRC the NA pump can pump just as much fuel as a TD pump, it will just smoke more until boost comes up......or you could advance the go pedal more and more as boost rises and get very little smoke.
« Last Edit: September 15, 2011, 01:56:19 pm by rabbitman »
