Author Topic: 1.6td shift points  (Read 8066 times)
Reply #15September 12, 2011, 11:58:28 am
Re: 1.6td shift points
« Reply #15 on: September 12, 2011, 11:58:28 am »
Oh it most certainly isn't bad. The gasser 1.6 and 1.7 (with proper valve springs) could spin 8k rpm. They are more or less the exact same motor as the 1.6 diesels.. Diesels have a slightly more robust bottom, so they'll take whatever you throw at em. ;)
i think the cranks & rods are tougher on the diesel. and the pistons are most certainly much tougher than gasser pistons..
back in the day, people would slap a gas head on a diesel engine, and NOS the hell out of it..
Reply #16September 12, 2011, 03:07:13 pm
punkvideo81
  • 168
« Reply #16 on: September 12, 2011, 03:07:13 pm »
Thanks for all your input everyone. I look forward to stretching my engine's legs a little more in the near future...then I've gotta get around to installing the VNT 15 I have sitting around for even more fun. Are any of you going to H20 int'l in Ocean City, MD later this month??? I'll be there.
'81 Caddy 1.6 TD
Reply #17September 12, 2011, 03:26:21 pm
« Reply #17 on: September 12, 2011, 03:26:21 pm »
you have a VNT 15 and its not on your car?!?
i woulda done it already. its gonna be night and day different  ;)
Reply #18September 12, 2011, 03:34:54 pm
punkvideo81
  • 168
« Reply #18 on: September 12, 2011, 03:34:54 pm »
I can't wait to get that VNT on, and a gasser intake as well. Should be a big wake up for it :)
'81 Caddy 1.6 TD
Reply #19September 12, 2011, 03:40:53 pm
« Reply #19 on: September 12, 2011, 03:40:53 pm »
its gonna perform as good, if not better than my engine, because you have a REAL TD fuel pump.. i dont, but i DO have a fresh, modified n/a pump..
Reply #20September 13, 2011, 08:41:56 pm
« Reply #20 on: September 13, 2011, 08:41:56 pm »
Same fueling capabilities. KEv, just put an LDA on your fresh na pump. BOOM a real TD pump appears out of thin air.
Reply #21September 13, 2011, 09:07:47 pm
damac
  • 531
« Reply #21 on: September 13, 2011, 09:07:47 pm »
I just went through this recently and found some snags in just putting my turbo pump on a good na body.
The delivery valves were smaller on na pump so the lines wouldn't reach the same?
Also as soon as I took the top off I found I could not seperate that governor arm from the groove like I have typically seen because it was one piece on the na pump, meaning I had to break it all down!  Ok in the end I guess since I resealed everything but I wanted it to be a quicker project.
I had another working but leaking turbo pump so I took that whole assembly with the turbo top and distribution head and it seems to be working on the car now.
1985 turbo diesel jetta
Reply #22September 13, 2011, 11:03:43 pm
nathan_b
  • 361
« Reply #22 on: September 13, 2011, 11:03:43 pm »
are you sure you dont have an aaz pump?
they have larger delivery valves
Reply #23September 14, 2011, 11:44:26 am
« Reply #23 on: September 14, 2011, 11:44:26 am »
wrong.. the n/a pump has a fuel limiter pin. ive made n/a fuel pumps into TD pumps before. i know what it takes..
gotta push that pin out of the way, or get rid of it all together..
Reply #24September 14, 2011, 06:35:42 pm
« Reply #24 on: September 14, 2011, 06:35:42 pm »
if it is so easy, why not do?
So the TD pump that I have an N/a top on right now.. is better than a normal na pump?
Reply #25September 14, 2011, 06:51:47 pm
nathan_b
  • 361
« Reply #25 on: September 14, 2011, 06:51:47 pm »
I have a bosch Ip rebuild for our 4cyls and it showed a map that the td pump had a higher potential fuel output. stock that is.
Reply #26September 14, 2011, 07:45:17 pm
« Reply #26 on: September 14, 2011, 07:45:17 pm »
because of the LDA..
un hook the LDA.. then a TD pump, and n/a pump would be exactly the same..
Reply #27September 15, 2011, 07:52:24 am
« Reply #27 on: September 15, 2011, 07:52:24 am »
unhook the LDA? iirc, the whole top just pops off and there was no difference in the bottom of the pumps between na and td.. but i could be wrong.
Reply #28September 15, 2011, 01:47:25 pm
« Reply #28 on: September 15, 2011, 01:47:25 pm »
all i was stating, was that the pumps are identical with no boost applied..
Reply #29September 15, 2011, 01:51:18 pm
damac
  • 531
« Reply #29 on: September 15, 2011, 01:51:18 pm »
No, I have multiple pumps from running vehicles that I compared, all the td's were the same and longer than the na?
I also forgot about that pin in the na body.  I grinded it away with a dremel
