Author Topic: vanagon IP issues  (Read 3913 times)
September 10, 2011, 05:45:01 pm
motomike33y
  • 190
vanagon IP issues
« on: September 10, 2011, 05:45:01 pm »
just got my vanagon on the road for my annual usage.  Noticing two issues.  When the van is warm--45 minutes driving at 60mph, then sitting for a while-I'm encountering starting difficulties.  Having to activate glow circuit/use cold start knob, etc.  It starts easily when cold.  Second, a couple times the IP would not accellerate when I stopped at an intersection.  Once it even died, but normally it idles and I have to either feather the accellerator until it decides to work, or go back and manually do the same thing with the lever on the pump.  It doesn't happen consistently, but it happened twice today-both time when engine was warmed up.  Any thoughts?  I'm thinking of contacting Giles about rebuilding my other pump for it, but in the meantime I'd like to solve this problem.  thanks.  mike
82 vanagon 1.6 waiting rebuild
81 jetta w/dasher 1.5 engine
91 jetta w/ 85 golf 1.6 NA- work in progress           suzuki samurai hardtop that may someday be diesel
2012 golf tdi
Reply #1September 11, 2011, 06:55:11 am
  • 1739
Re: vanagon IP issues
« Reply #1 on: September 11, 2011, 06:55:11 am »
sounds like your pump is going, time for Giles to perform some magic for you
Reply #2September 11, 2011, 08:23:27 am
« Reply #2 on: September 11, 2011, 08:23:27 am »
I'd say you have two issues.
First, I think you are sucking in some air
Second, I think you have some bad wires and need to do a voltage drop test (hard hot starts)
