Author Topic: GLI ground peices  (Read 4585 times)
January 31, 2006, 05:38:45 pm
superman293
  • 93
GLI ground peices
« on: January 31, 2006, 05:38:45 pm »
does anyone know where i can find and buy stock ground pieces for a 2000 jetta GLI?
thanks
Reply #1January 31, 2006, 05:59:13 pm
RabbitGTDguy
  • 1274
GLI ground peices
« Reply #1 on: January 31, 2006, 05:59:13 pm »
depending on what your looking for and if you have a part number... www.worldimpex.com or www.autohausaz.com or www.germanautoparts.com can get you about anything, and all OEM... type in the p/n and if they can get it, usually it comes up. I always compare impex's prices though against the dealer, sometimes they are less, sometimes they are more. Impex is your best bet intially i think.
Joe
1972 VW Westfalia
Reply #2February 01, 2006, 08:26:48 pm
hillfolk'r
  • 1532
GLI ground peices
« Reply #2 on: February 01, 2006, 08:26:48 pm »
um,,,sorry to say but,,,igot turned off from impex when they wanted 120 a hole for the rings  on my tdi buildup,,i ended up finding them for 18 a hole,,,so impex can blow me all night the way i like it ,,but thats just my opinion :shock:
Throttle cables ftw
Reply #3February 01, 2006, 11:45:50 pm
fspGTD
  • 1529
GLI ground peices
« Reply #3 on: February 01, 2006, 11:45:50 pm »
For genuine VW parts that are cheaper than Impex, try this place:
http://www.1stvwparts.com/
I recently completed an order through them, and was pretty pleased.  Be warned that their online ordering system was a little flakey when I used it though.  I was in the final stages of an order when it unexpectedly and with no warning aborted me out to the home page.  Previously to that, my shopping cart kept getting emptied without my request.  I called them up on the phone to see if my order was recorded, it wasn't, so I entered it over the phone which worked OK.  The guy I spoke to, "Zeke", seemed pretty nice.  My order arrived well packaged and in a timely manner.  I would use them again.
Jake Russell
Reply #4February 02, 2006, 03:43:12 am
RabbitGTDguy
  • 1274
GLI ground peices
« Reply #4 on: February 02, 2006, 03:43:12 am »
Quote from: "hillfolk'r"
Like I said...they are good on some things...not on others. They are the closest to the dealer on the aftermarket and compete with them for that reason... I ended up with mine through www.germanautoparts.com for the Goetze rings at a good price too. Still will compare on some things. The price p/ hole is still slightly less than dealer but most other places can't do much better either. Alot of the others get pieces in stock but once they are sold out they are forced to sell at that price until the manufacturer can resupply at the lower price again.
Joe
1972 VW Westfalia
Reply #5February 02, 2006, 05:01:23 am
therabbittree
  • 299
GLI ground peices
« Reply #5 on: February 02, 2006, 05:01:23 am »
yeah i've tryied to find the $18 ring set too and the guy blake bought from says they are outa stock..argh $18 vs $120 ..big difference..so my engine has the stock 150k rings and bearing it it..should be fine...
later deo
Reply #6February 02, 2006, 06:41:26 am
RabbitGTDguy
  • 1274
GLI ground peices
« Reply #6 on: February 02, 2006, 06:41:26 am »
www.germanautoparts.com didn't show them in stock, but I was able to call them and get the OEM's for 20/hole....
Very good source to call if you need them in the future...
Joe
1972 VW Westfalia
Reply #7February 02, 2006, 03:37:51 pm
hillfolk'r
  • 1532
GLI ground peices
« Reply #7 on: February 02, 2006, 03:37:51 pm »
at the time,i found  2 or 3 sites with the 20$ rings,,ipaid like 250 for new valves from them,after that i started pricing stuff more carefully ,,felt robbed cause ifound them cheaper too after the fact,, they didnt even lubricate it first before sticking me, i wouldnt use them (impex) unless no one else had anything anywhere,basically a last resort,but like i said,jus myopinion :oops:
Throttle cables ftw
