Author Topic: FS Injection Pump's  (Read 5280 times)
September 06, 2011, 06:07:41 pm
abnkeis
FS Injection Pump's
« on: September 06, 2011, 06:07:41 pm »
I have one pump that I took off my running Jetta and stored for a couple years now. $100
****SOLD****I have one pump that the main seal started leaking. $50
****SOLD****I have one pump that has the head off and most parts with it. $25
« Last Edit: September 10, 2011, 08:42:50 pm by abnkeis »
Reply #1September 08, 2011, 06:29:49 pm
hairyhuevos
  • 12
Re: FS Injection Pump's
« Reply #1 on: September 08, 2011, 06:29:49 pm »
i have a 93 td golf. Would like to know if any of those would fit.
1.6 and 1.9 td
Reply #2September 08, 2011, 06:41:54 pm
« Reply #2 on: September 08, 2011, 06:41:54 pm »
they will ALL FIT.. but how much modifying are you willing to do?
none of them are a bolt-on-and-go affair..
the only pump that will swap on your car with no other work, is the pump specifically from an AAZ engine..
Reply #3September 08, 2011, 07:42:57 pm
rallydiesel
  • 1880
« Reply #3 on: September 08, 2011, 07:42:57 pm »
It would help immensely if the OP would provide some details on each pump.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #4September 09, 2011, 10:52:41 pm
abnkeis
« Reply #4 on: September 09, 2011, 10:52:41 pm »
Pics added, hope that helps with questions. I used them on my 91 TD.
Reply #5September 10, 2011, 05:56:25 am
Blocksmith
  • 261
    Wrench Lurker
« Reply #5 on: September 10, 2011, 05:56:25 am »
PM'd
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
Reply #6September 18, 2011, 07:14:11 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« Reply #6 on: September 18, 2011, 07:14:11 pm »
Why did you take your pump off your jetta
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #7September 18, 2011, 07:24:45 pm
abnkeis
« Reply #7 on: September 18, 2011, 07:24:45 pm »
I took it off to rebuild the motor, but decided not to rebuild and instead part everything out.
Reply #8September 18, 2011, 10:53:56 pm
dankcorey22
  • 379
    Cummins!
« Reply #8 on: September 18, 2011, 10:53:56 pm »
What year is that jetta or is that the OE that came on the car? TD?
Do you have the IP part #?
-Corey
Reply #9September 22, 2011, 07:26:08 pm
abnkeis
« Reply #9 on: September 22, 2011, 07:26:08 pm »
-Corey
Sorry for the delay in responding.
I had the pump on my 91' TD Jetta, but had bought the IP from a guy shortly after he had had it rebuilt. I probably only put a few thousand miles on it before I tore the motor down for a rebuilt that I never finished, hence the reason it is for sale on here.
The numbers on the IP are as follows:
NR 0460 494 135
VE R 134-2
068 130 1090
1144 354 377
Thanks,
Dustin
