Opinions on this lube here
Topic: Opinions on this lube here (Read 2769 times)
September 05, 2011, 07:40:28 pm
wdkingery
September 05, 2011, 07:40:28 pm »
Sorry I didn't know where to post this so I stuck it here.
I can get this for cheap.. But is it of any value??
Uploaded with
ImageShack.us
September 05, 2011, 08:13:12 pm
nathan_b
Re: Opinions on this lube here
September 05, 2011, 08:13:12 pm »
Well, if you want to run an electric pump and have a separate oil circuit and reservoir for your turbo probably would be great.
For a combustion engine, I wouldn't dare put it in.
81 caddy frankentd 02a, 99.9 tdi jetta, 00 golf
September 05, 2011, 11:40:15 pm
September 05, 2011, 11:40:15 pm »
yea, its for turbine engines that turn 30k rpms or more.. im sure its thin as hell, so it can flow thru the bearings at those speeds..
im with nathan, no way i would EVER put that in the crank case of my engine..
September 06, 2011, 01:33:02 pm
silentdub
September 06, 2011, 01:33:02 pm »
I didn't see any weight info on that. I am sure that there are better oils with more information.
September 07, 2011, 12:21:08 am
rabbitman
September 07, 2011, 12:21:08 am »
I was flying in a bell 212 a couple months ago and there was a sticker on the side of the chopper that called for that oil. I'd never use it in anything but a turbine.
September 07, 2011, 09:35:47 am
clbanman
Cambridge, Ontario
September 07, 2011, 09:35:47 am »
As mentioned, it is a mil spec oil that is not for our engines. Per BP's specs, it is a 3 cSt synthetic lubricant, and kinematic viscosity at 40 degrees C is 12.46 cSt. By comparison, Mobil 1 synthetic diesel oil at a 5W-40 grade at 40 degrees C has a viscosity of 97.9 cSt. (Higher number is "thicker".
Calvin
91 VW Golf 1.6NA 5spd
