1Y/aaz air flow or other issue?
Topic: 1Y/aaz air flow or other issue? (Read 5316 times)
September 05, 2011, 01:33:52 am
carrizog60
September 05, 2011, 01:33:52 am »
hello
what is the air flow that such engines can move?
i have a 1Y converted to turbo(with 1Y manifold) and want to know the flow of this engines from stock.
if you know the 1.6 specs feel free to post
thanks
edit:half page down i add other question about smoke,feel free to help
Last Edit: September 07, 2011, 03:40:09 am by carrizog60
Portugal
September 05, 2011, 07:15:22 am
Re: 1Y/aaz engine air flow
September 05, 2011, 07:15:22 am »
I asked this same question couple of years ago to try to figure out what size air filter to use on my 1Y. Never got an answer. I did some digging on sites which sold those engines as generators and water pumps ,with limited information . In the end going from 2" to 2.5 " runners from the inlet of the air filter to the intake manifold really woke that engine up
September 05, 2011, 10:18:33 am
September 05, 2011, 10:18:33 am »
Depends on your boost level and maximum RPM.
If you go here:
http://www.not2fast.com/turbo/glossary/turbo_calc.shtml
And then fill in the relevant details (your max boost, max RPM, bore/stroke, etc) it will tell you how many CFM you need.
September 05, 2011, 10:28:08 am
carrizog60
September 05, 2011, 10:28:08 am »
i have a 1Y with a gt2052 and was searching for how much boost will be ideal...
plans go on 1.5/1.6 max what do you guys think?
Portugal
September 05, 2011, 08:11:48 pm
nathan_b
September 05, 2011, 08:11:48 pm »
why does it matter???
September 05, 2011, 11:30:03 pm
September 05, 2011, 11:30:03 pm »
i dont think it really matters with air filter size.. you cant really go too big.
if it LOOKS too small to you, then it probably is..
September 06, 2011, 01:43:36 am
carrizog60
September 06, 2011, 01:43:36 am »
i am not talking air filter size,just want to know how much boost to run.
dont want to stress the engine and be on the efficient zone of the turbo.
Portugal
September 06, 2011, 02:49:30 am
September 06, 2011, 02:49:30 am »
got a compressor map for your turbo? that will tell you EVERYTHING you want to know
September 06, 2011, 06:36:33 am
nathan_b
September 06, 2011, 06:36:33 am »
I think an egt gauge will give you more real info regarding how much boost, because it depends on fueling more than the potential cfm of the motor.
thats really the whole idea of boost. to force more cfm than it was capable of..
Last Edit: September 06, 2011, 08:58:33 am by nathan_b
September 06, 2011, 08:38:05 am
September 06, 2011, 08:38:05 am »
which trim gt2052 do you have?
September 06, 2011, 09:08:49 am
September 06, 2011, 09:08:49 am »
if its the 48 trim i think it is, i would say around 20-25psi. looks like a good turbo for that boost range
Reply #11
September 07, 2011, 03:38:37 am
carrizog60
Reply #11 on:
September 07, 2011, 03:38:37 am »
my guess would be A/R 45 as its the turbo that came on the audi 2.5 tdi 150hp.
my plan is to run the most efficient boost that the turbo can produce,and then tune the pump to match it.
right now i have a 1.6 pump with stock 9mm head and with the turbo at 1bar i only smoke greyish at full pedal.lots of smoke but grey so i think i still have room for more fuel,even at 1 bar.
have to replace the pump had as the pump is maxxed out and governor mod included.
or ,on another note,is the smoke other issue?
i feel ceptical about the 1.6 pump with 1.9 injectors,and the pump also seems to leak a bit on the head side, but nothing major.
timing is set at 1.00 or 1.05,can recall for sure, and it starts fine on cold,hot whatever.
just feel a little plin plin on idle and light accelaration.other situations is fine so i dont messed with it yet.
i have a spare 1.9 ecodiesel pump,but installed the 1.6 because i dont like the dual spring assembly on the accelarator shaft...
Portugal
Reply #12
September 07, 2011, 09:58:39 pm
MJF
Re: 1Y/aaz air flow or other issue?
Reply #12 on:
September 07, 2011, 09:58:39 pm »
Some years ago I had 150hp 2,5 V6 TDI turbo with 1,6. I wanted to run ~1,5-1,6bar max. But the more I turned fueling up, higher the boost went. With my pump maxxed out, boost rised to 1,9bars vanes full open. Dynoed 173hp/280nm with that setting, torque could have been adjusted to lower rpm by vane settings. I liked it a lot, very nice turbo for dailydriver
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #13
September 08, 2011, 01:06:33 am
carrizog60
Reply #13 on:
September 08, 2011, 01:06:33 am »
thanks mjf.
you were controling the vanes just by a WG pressure can right?mine is that way but i dont like it much as its only good or for cruising or max boost,when accelarating the car will go better when vanes opens at 1 bar,but with half throtle boost will go down a bit after and at wot boost wont go more than 1.1/1.2 so how can you get that pressure?i have 9mm head still but going 11mm.
the grey smoke is what i think?
thanks
Portugal
Reply #14
September 08, 2011, 01:37:35 am
MJF
Reply #14 on:
September 08, 2011, 01:37:35 am »
You are right, I had just boost pressure can controlling. Simple, but not that good. I had 10mm pump with that setup.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
