Author Topic: question for the canadian gurus  (Read 3525 times)
September 01, 2011, 05:12:33 pm
ilikevwdiesel
  • 1202
« on: September 01, 2011, 05:12:33 pm »
would all 94 Golf AAZ cars have a regular IP with a K14 turbo or did some of them come with eco engines?
My Bio
Reply #1September 01, 2011, 06:57:12 pm
RadoTD
  • 513
    Stage WTF
Re: question for the canadian gurus
« Reply #1 on: September 01, 2011, 06:57:12 pm »
As far as I'm aware, they will all be normal. I've never seen/heard of an eco mk3 in Canada
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #2September 01, 2011, 08:06:21 pm
410
  • 581
« Reply #2 on: September 01, 2011, 08:06:21 pm »
Same here.  I have seen differences in turbos though.  Some with the triangular three bolt flange and some with the four bolt flange like the 1.6td.  I worked on one that looked to have the garrett t2 turbo as well.
Reply #3September 01, 2011, 08:06:31 pm
« Reply #3 on: September 01, 2011, 08:06:31 pm »
Ecos are very rare. I think they were primarily on the 92 Passat. As for the turbo I have heard that the early mk3s had the K14 while the later ones were all K03s but I don't know for sure
Reply #4September 07, 2011, 06:12:54 am
Golf/Jetta
  • 102
« Reply #4 on: September 07, 2011, 06:12:54 am »
I've never seen an eco as stock in a MK3 but I have seen a modified 1.9L as an eco. Just block the LDA from getting air from the turbo.
'97 Jetta - 4Dr - 1.9 TiDi (Forth Car)
'94 Jetta - 4Dr - 2.0L Swaped in an AZZ - Almost done 2011 b4 Winter (Third Car)
Blue '87 Golf - 2Dr - Tags (First Car)
Red '92 Jetta (W) - 4Dr - Sold to Friend For $200 (Second Car)
Thanx For Answering My Posted Question's/Comments...
Reply #5September 07, 2011, 12:29:10 pm
« Reply #5 on: September 07, 2011, 12:29:10 pm »
thats NOT an eco.. thats basically a TD with a n/a pump on it now. ECO cars have an LDA, and it functions..
ECOs have smaller turbos, smaller plungers in the injection pump, catalytic converters, and a few other differences. they ARE DIFFERENT, and as tyler said, are very rare..
Reply #6September 07, 2011, 04:23:12 pm
Henchman
  • 183
« Reply #6 on: September 07, 2011, 04:23:12 pm »
MK3 AAZ could have a k14 or a k03.  All MK3s that I have seen (20 or so) have LDA pumps.  My 93 b3 passat with the same engine has a non-lda pump, I assume to keep the mpgs up because the car is heavier.   I have also seen non A/C from the factory as well as TDI sprockets.   FYI, all AAZs with regular sprocket will fail.  MK3s seem to go between 300k km and 400k km (about 75% I have parted out have failed).
Ian
Reply #7September 08, 2011, 07:10:23 pm
« Reply #7 on: September 08, 2011, 07:10:23 pm »
Not the 1.9 eco. It is identical to the true TD version with the exception of the LDA. Although some did come with an 8mm H/R, but I think that was only the NA versions.
Reply #8September 08, 2011, 09:22:25 pm
CdnVWJunkie
  • 309
« Reply #8 on: September 08, 2011, 09:22:25 pm »
I've had several B3/4s and none of them have had the LDA equipped IPs.  Coincidence maybe?  A couple of the early ones, like the recent part out, had the K14 while the later ones had the K03s.
