Author Topic: In vancouver need injector lines HELP!!!!!  (Read 2744 times)
August 27, 2011, 01:38:17 pm
kaneb
  • 164
    • www.dasdubbers.org
« on: August 27, 2011, 01:38:17 pm »
Hi
Made the trip out to Vancouver from Calgary for the great canadian car show.  Got a cracked line for #2 in abbotsford.  Had a spare NA line but it hits the LDA on the inj. pump so i need to find a TD line for a 1.6L to be safe!! If anyone has some or knows where I can find some please let me know.  Don't want to have issues on my trip back.
Number is 403-975-5263--
Would be greatly appreciated and thank you!!
Kane
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
Reply #1August 27, 2011, 01:45:49 pm
Re: In vancouver need injector lines HELP!!!!!
« Reply #1 on: August 27, 2011, 01:45:49 pm »
i had your number half way dialed.. then i realized you meant Vancouver, CANADA..
sorry, i cant help you.. had you been in Vancouver, Wa, i could have been of help..
Reply #2August 27, 2011, 02:31:56 pm
guy plain
  • 121
« Reply #2 on: August 27, 2011, 02:31:56 pm »
when are you heading back? im kindof on the way....i can look and see if i have a spare good one...im in ashcroft .....if you where to come up the canyon on your way to kamloops you,ll go by my place.
Reply #3August 27, 2011, 03:04:27 pm
Thezorn
  • 381
« Reply #3 on: August 27, 2011, 03:04:27 pm »
Try messaging radotd or smokeyeddy, they both live in van and might be able to help you out.
Compounded 93 AAZ
Reply #4August 27, 2011, 03:17:48 pm
92EcoDiesel Jetta
« Reply #4 on: August 27, 2011, 03:17:48 pm »
Wha kind of van? Kinda tight eh. ;)
Reply #5August 27, 2011, 03:58:19 pm
Mark(The Miser)UK
  • 1557
« Reply #5 on: August 27, 2011, 03:58:19 pm »
You could swing the pump and it's pulley one notch retarded on the timing belt, so that the pump is more upright, all should be well with your 'wrong' line I'm sure ;D
Mark-The-Miser-UK
Reply #6August 27, 2011, 10:23:30 pm
nathan_b
  • 361
« Reply #6 on: August 27, 2011, 10:23:30 pm »
just bend the line....
Reply #7August 28, 2011, 02:08:46 am
Mark(The Miser)UK
  • 1557
« Reply #7 on: August 28, 2011, 02:08:46 am »
It was line bending that got you in this spot in the first place , all be it a few million times. Justshift your pump
Mark-The-Miser-UK
Reply #8August 28, 2011, 05:50:41 am
nathan_b
  • 361
« Reply #8 on: August 28, 2011, 05:50:41 am »
It's not bending lines that cracks them, because they ARE ALL BENT. lol.
it's not loosening the lines when you move the pump or just plain corrosion.
Reply #9August 28, 2011, 07:22:00 am
kaneb
  • 164
« Reply #9 on: August 28, 2011, 07:22:00 am »
Na i loosen off my lines im heavy diesel mechanic i know better :D .  Pretty much what happened was im from calgary and the altitude is different when i got to abbotsford my idle was quite low and the engine was not as smooth vibrating and the line cracked while i hit rush hour.  Stop and go traffic was not a good time.  I brought my idle up replaced the line and am going to retard my timing a touch like said above to get home.  Unless i score some lines at GC today.  You don't bend inj. lines. Especially where i would need to so close to the pump, the line wouldnt seat properly then.  Thanks for the help guys!
www.dasdubbers.org
