Author Topic: fresh rebuild ran good now not so much why??  (Read 2981 times)
August 27, 2011, 09:30:46 am
colhel59
  • 34
« on: August 27, 2011, 09:30:46 am »
so last night finally got my aaz in my 92 gti but have some issues now. i primed every thing up had fuel comin out the injectors closed the lines up hit the plugs for a burn and she fired right up ran suprisingly well.  i was just runnin it off a jerry can of fuel so i let it warm up a bit and started brappin the throttle some  was all good till i brapped the throttle on time and it reved then shut down. so i tryed restarting it started but wouldnt idle and now smoke white like a son of a gun (raw fuel) so what should i check?? timing is a first for sure but my consurn is if soming got sucked in the pump i guess any thoughts???
Thanks guys
Colton ::)
Reply #1August 27, 2011, 11:06:30 am
Thezorn
  • 381
Re: fresh rebuild ran good now not so much why??
« Reply #1 on: August 27, 2011, 11:06:30 am »
Timing is definatley the first thing, takes like 10 mins to check the mech. timing, also check the sprocket on the end of the crank, who knows it could have slipped, easiest way it to just try and tighten the 12 point 19mm bolt, if it moves then chances are it slipped.
Compounded 93 AAZ
Reply #2August 27, 2011, 01:25:08 pm
« Reply #2 on: August 27, 2011, 01:25:08 pm »
when i do the can thing i use a beetle filter for carb on end of my hose.. if non filtered you could have sucked something up :(
Reply #3August 28, 2011, 08:48:12 am
colhel59
  • 34
« Reply #3 on: August 28, 2011, 08:48:12 am »
i did the D shaped crank nose mod so it wouldnt slip. ill check the timing this afternoon to double check.
Reply #4August 28, 2011, 11:18:19 am
« Reply #4 on: August 28, 2011, 11:18:19 am »
the cam can still slip..
Reply #5August 30, 2011, 10:09:33 pm
colhel59
  • 34
« Reply #5 on: August 30, 2011, 10:09:33 pm »
so found the problem the belt skipped on the IP so it was was retared i advanced it one notch and retimed to 1.05mm and was golden but why would it skip cuz the cam was dead on fresh belt and tenchener..
Thanks for your help
Reply #6August 30, 2011, 10:13:30 pm
colhel59
  • 34
« Reply #6 on: August 30, 2011, 10:13:30 pm »
also have another problem my tach reads to high its has the stock aaz sepentine pullys and i found a diesel tach to use for my car 92 gti. Is the pullys just to big or can i put a resistor in line.
Thanks again guys
Colton
Reply #7August 31, 2011, 03:24:40 am
nathan_b
  • 361
« Reply #7 on: August 31, 2011, 03:24:40 am »
are you claiming that you fit serpentine a/c from a mk3 into a mk2?
Reply #8August 31, 2011, 06:30:16 am
colhel59
  • 34
« Reply #8 on: August 31, 2011, 06:30:16 am »
No it is non a/c I just uesed the belt system from the aaz including the alt.
Reply #9August 31, 2011, 07:44:13 am
nathan_b
  • 361
« Reply #9 on: August 31, 2011, 07:44:13 am »
without the compressor I think that it will be off.
Reply #10August 31, 2011, 09:12:28 am
colhel59
  • 34
« Reply #10 on: August 31, 2011, 09:12:28 am »
That doesn't make sence cuz the crank pully is still driving the alt.no matter what other acc you put on it
Reply #11September 01, 2011, 06:11:23 am
colhel59
  • 34
« Reply #11 on: September 01, 2011, 06:11:23 am »
Did a little reserch on here and found I need to change some resistors in my tach. Its off because at alt is just turning that much fasted diffrent pully sizes
