LDA for sale on german ebay
Topic: LDA for sale on german ebay (Read 4151 times)
July 22, 2004, 03:46:44 am
Caddy-Daddy
User+
July 22, 2004, 03:46:44 am »
What do you thik of this? does it add 20 Hp?
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&category=61310&item=7911748580&rd=1
Caddy's Rule
July 22, 2004, 09:30:15 am
BlackTieTD
July 22, 2004, 09:30:15 am »
it will definitely help performance. 20hp i don't know.
you could also modify the profile of the cone in your existing pump to achieve the same results.
dr. diesel or andy2 might be able to shed more light on this... i haven't done this mod myself (yet).
edit: if someone could post a picture of a stock cone, you could compare them side-by-side to see where you need to remove material to achieve the profile of the 20hp ebay cone.
July 22, 2004, 10:19:00 am
Turbo DS
July 22, 2004, 10:19:00 am »
Print that photo. Then, use the picture as a template, when you cut/machine your existing control cone. It is very easy to do, just remember to highly polish where the pin makes contact with the cone.
July 23, 2004, 07:11:31 pm
RedRotors
July 23, 2004, 07:11:31 pm »
Here's the picture of a stock 1.6TD boost pin.
Hope this help..
Marc/
2k1 Golf TDI, 11mm pump, HFLOX Warp 5, VNT17, Wavetrac, 4" Lift
91' VW Golf Country
94' Dodge RAM 2500, 4x4, Cummins, 5 spds, 191's, 215hp injectors, SB Clutch
03' Dodge RAM 2500, 4x4, Cummins, 6 spds, MBPR 4 ", custom intake, Smarty Jr
www.mikrotuning.com
www.hflox.com
