Author Topic: WTB 1.6 TD fan/motor  (Read 3628 times)
August 08, 2011, 07:11:06 pm
southernman
  • 72
« on: August 08, 2011, 07:11:06 pm »
Guys, I've got an MK1 with 1.6 NA dsl, and am wanting to upgrade the fan and motor assy on it.
I've read on the forums here that the TD fan is 6 blade, versus the 4 blade on mine, and that it is 280mm dia, which matches the OD of my existing fan.
Anybody got a good unit they want to sell ? I'm in NC 27613 zip...
Thanks !
D
'82 VW Caddy w/ 1.6 NA Diesel - completely stock.
Reply #1August 08, 2011, 07:15:35 pm
rallydiesel
  • 1880
Re: WTB 1.6 TD fan/motor
« Reply #1 on: August 08, 2011, 07:15:35 pm »
I just bought a brand new one for $45 bucks. That's after spending $60 for a used one from a junkyard that ended up not working  >:(. Check the worldpac/autohauz sites. The new ones have 6 blades and are significantly smaller and lighter than the old oem ones.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2August 08, 2011, 07:24:42 pm
southernman
  • 72
« Reply #2 on: August 08, 2011, 07:24:42 pm »
Thanks my friend. Only problem is, I can't buy directly from Worldpac, so I'm assuming you mean through one of their distributors. I'll check out Carquest tomorrow. Again, thanks for the (quick) feedback !
D
Reply #3August 21, 2011, 09:32:34 am
GEE-BEE
  • 1604
« Reply #3 on: August 21, 2011, 09:32:34 am »
get a scirocco 16v 250 watt / dual speed
ebay seller
 moogie2498 has them
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
