Author Topic: Tore the head down finally  (Read 3472 times)
August 08, 2011, 09:07:42 am
silentdub
  • 135
« on: August 08, 2011, 09:07:42 am »
I got this 85 1.6d and man it is in very good condition.
No cracks anywhere and just one bent valve.
I was able to pull the glow plugs and injectors out with ease too, I have heard horror stories in the past.
I just picked up all new Brass Valve Guides, other than a cleaning and porting should I have anything else done to this little fella?
I have a 2 notch gasket, so I will have it surfaced enough to clean it up and may go to a thicker gasket to compensate.
Reply #1August 08, 2011, 09:23:44 am
Re: Tore the head down finally
« Reply #1 on: August 08, 2011, 09:23:44 am »
The valves are recessed so you do NOT need to go to a thicker gasket. The piston protrusion is the only determiner of the thickness you need.
I think you have it covered. Search dave vissard or viserd or some similar spelling. We had a thread on here on how to blend the bowl area better that would put you in the right mindset for porting.
Reply #2August 08, 2011, 10:51:52 am
92EcoDiesel Jetta
« Reply #2 on: August 08, 2011, 10:51:52 am »
Yes the valves are recessed into the head but if the head is cut, the valves are recessed less while the piston protrusion remain the same. Something has to change to compensate. Thicker head gasket? or cut piston?  cut valves to seat deeper?
Reply #3August 08, 2011, 12:23:30 pm
Mark(The Miser)UK
  • 1557
« Reply #3 on: August 08, 2011, 12:23:30 pm »
Just let the valves tap into the pistons a little. :o I find the exhaust valves will get kissed just before TDC, and miss at TDC on my car.
Mark-The-Miser-UK
Reply #4August 08, 2011, 01:39:54 pm
silentdub
  • 135
« Reply #4 on: August 08, 2011, 01:39:54 pm »
Exactly my thinking.
This engine looks very clean too, I pulled the oil pan, nothing in it, no pieces of metal or anything, not even a build up of burnt oil, looks black, but free from any debris.
Reply #5August 08, 2011, 05:37:34 pm
« Reply #5 on: August 08, 2011, 05:37:34 pm »
If you are planning on cutting .100" then yes and the head is probably junk anyway. A couple thousands to clean it up aren't going to matter.
To do it correctly I have been told would be to heat the head up to plastic state and press it flat again. Just cutting the surface won't realign the cam journals. If the head is warped then that is probably what they should do.
I think running a thicker gasket is a bad idea IMHO.
Reply #6August 08, 2011, 05:52:54 pm
rallydiesel
  • 1880
« Reply #6 on: August 08, 2011, 05:52:54 pm »
If you have it just taken down a few thousandths than you shouldn't worry about valve/piston contact. If you are still worried, you could hand lap the seats. I would still measure piston protrusion before ordering the new headgasket to ensure the previous owner actually used the right size.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #7August 09, 2011, 04:36:25 am
DJPyro
  • 66
« Reply #7 on: August 09, 2011, 04:36:25 am »
http://www.vwdiesel.net/forum/index.php?topic=15782.0
That's the porting article in question.
Reply #8August 09, 2011, 09:17:02 am
silentdub
  • 135
« Reply #8 on: August 09, 2011, 09:17:02 am »
Thanks man, I'll look at that guy now.
I am about 80% thinking of a custom header. If I can do it for under $100.00, I'll do it and have some sweet exhaust flow.
Reply #9August 09, 2011, 12:15:38 pm
« Reply #9 on: August 09, 2011, 12:15:38 pm »
the really proper way is to cut valve seats and  precup cups to the proper  depth
Reply #10August 10, 2011, 08:17:03 am
silentdub
  • 135
« Reply #10 on: August 10, 2011, 08:17:03 am »
It's not going to matter anyway, the head it perfect the way it is now. There are no cracks, cuts, burns. The surface is flat within spec, so I'll probably just have it cleaned up and surfaced.
In theory, if I had to cut it, I could cut it to make up the difference between the 2 and 3 notch gasket and be perfectly fine. The compression and clearance wouldn't change.
Reply #11August 10, 2011, 02:04:09 pm
« Reply #11 on: August 10, 2011, 02:04:09 pm »
That isn't the main problem. Quench is what will be messed with when playing with the different thicknesses of gasket.
VW didn't give different thickness gaskets to raise or lower compression, but to burn the fuel.
Reply #12August 10, 2011, 05:07:03 pm
« Reply #12 on: August 10, 2011, 05:07:03 pm »
^ This, too fat HG you lose ~5 MPH for 0 gains(as measured on a ~50 MPH hill).
