Author Topic: Does the motor mount have to come off first to remove turbo drain line?  (Read 1990 times)
August 04, 2011, 08:49:40 pm
92EcoDiesel Jetta
Anyone know and have done the job?
Reply #1August 05, 2011, 06:18:02 am
92EcoDiesel Jetta
Re: Does the motor mount have to come off first to remove turbo drain line?
« Reply #1 on: August 05, 2011, 06:18:02 am »
Anyone? Currently the turbo has been disconnected from the drain line but is stuck to the oil pan. Can the drain line and oil pan be removed without removing the motor mount? The drain line had a few bends in it and is captured in the motor mount.
Reply #2August 05, 2011, 06:44:38 am
« Reply #2 on: August 05, 2011, 06:44:38 am »
no you can remove.
Reply #3August 05, 2011, 06:51:14 am
« Reply #3 on: August 05, 2011, 06:51:14 am »
I re read and I don't know. I have not seen one with the drain line in the mount. I would assume it is only bolted to it? Other than that I would have no way to know if you have to take it off or not.
I would for sure think there is no way to remove the oil pan with the turbo connected to it. The drain line yes but you should be able to break that connection loose at the oil pan.
Reply #4August 05, 2011, 07:13:17 am
92EcoDiesel Jetta
« Reply #4 on: August 05, 2011, 07:13:17 am »
On mine the drain line runs through an opening in the motor mount. Isn't it the same on yours? The drain line flare fitting on the oil pan is frozen thus the reason to remove it as an assembly so I can free it and paint it.
