Author Topic: Electric fuel pump questions.  (Read 21111 times)
Reply #45October 06, 2012, 05:51:27 am
srgtlord
  • 797
Re: Electric fuel pump questions.
« Reply #45 on: October 06, 2012, 05:51:27 am »
how about no filter. Mine came with a small filter at the outlet of the pump that i deleted with a brass fitting from the hardware store.
Reply #46October 06, 2012, 11:21:27 am
« Reply #46 on: October 06, 2012, 11:21:27 am »
Facet posi flo arrived today! whats a good filter to run between it and the fuel tank it says in instructions one is required...
no filter on my setup..
Reply #47October 06, 2012, 03:21:07 pm
« Reply #47 on: October 06, 2012, 03:21:07 pm »
Id run it up in the bay after the filter and before the injection pump.
If you insist on having it under the car, some sort of capable in line filter will suffice to keep it clean of tank gunk.
Other people that haven`t used a filter were lucky enough to have a clean tank it seems. Will you be so lucky? Or will the pump die in short order?
Reply #48October 07, 2012, 10:27:34 am
« Reply #48 on: October 07, 2012, 10:27:34 am »
i like putting it BEFORE my filters.. then the filters are pressure fed, and they last soo much longer..
dont remember the last time i changed fuel filters!
Reply #49October 07, 2012, 10:32:23 am
« Reply #49 on: October 07, 2012, 10:32:23 am »
Don't see how it makes a difference? But anyway. lol I have had my filters on the suction side with no issue?
Reply #50October 07, 2012, 10:35:15 am
« Reply #50 on: October 07, 2012, 10:35:15 am »
suction is suction.. vacuum..
pressure pushes stuff thru the filter, rather than relying on being pulled thru..
pressure fed is better yo..
not saying yours was wrong, but that filters last better with a pressure feed..
Reply #51October 07, 2012, 10:36:31 am
« Reply #51 on: October 07, 2012, 10:36:31 am »
So it is not filtering as much? Yikes. lol
Reply #52October 07, 2012, 10:55:55 am
« Reply #52 on: October 07, 2012, 10:55:55 am »
well, there is obviously filter media present, and i doubt 5psi is literally pushing things thru my filter..
my racor 2 micron filter bowl is still spotless, so i doubt anything gets pushed thru the filters..
Reply #53October 07, 2012, 11:37:13 am
bbob203
  • 1789
« Reply #53 on: October 07, 2012, 11:37:13 am »
do any MAPS sell racor stuff? I think I'm gonna slap my oe filter out back and put a racor 2micon up front.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #54October 07, 2012, 11:57:19 am
« Reply #54 on: October 07, 2012, 11:57:19 am »
i run both filters up front, so its easy to get to them..
usually, racor filters arent carried at local parts stores, unless they deal with alot of marine or agriculture stuff..
Reply #55October 08, 2012, 09:55:50 am
srgtlord
  • 797
« Reply #55 on: October 08, 2012, 09:55:50 am »
Run the pump and regular fuel filter up front. It will make your life 100% easier down the road.
Reply #56October 13, 2012, 12:31:53 pm
monomer
  • 414
« Reply #56 on: October 13, 2012, 12:31:53 pm »
A pre filter like those on Mercedes will work perfect. Just enough of a filter to keep junk out of the pump. Filter are cheap and can be blown out.
Mercedes run three filter, with just the normal IP mounted lift pump. A in-tank strainer, and a pre filter/filter up front. No issues unless you get microbes.
That's my plan atleast. Still have yet to install the walbro lift pump.
-1983 Rabbit LX 1.6/1.9 VNT build
Michigan Volkswagen Enthusiasts
www.michiganvw.org
