pulling injection pump shaft seal
Topic: pulling injection pump shaft seal (Read 2627 times)
August 02, 2011, 04:22:28 pm
92EcoDiesel Jetta
August 02, 2011, 04:22:28 pm »
Anyone know the best way in pulling the injection pump shaft seal please post pics of the tool you use and tips and tricks. Is there a special tool for such a small seal? The shaft is 17 mm diameter and the seal is about 1/4 inch wide.
August 02, 2011, 05:12:38 pm
vdubspeed
Re: pulling injection pump shaft seal
August 02, 2011, 05:12:38 pm »
notch an old flathead screwdriver on the side so it becomes a small pry.
Works a charm.
August 03, 2011, 07:42:06 am
92EcoDiesel Jetta
August 03, 2011, 07:42:06 am »
Quote from: vdubspeed on August 02, 2011, 05:12:38 pm
Works a charm.
What are you prying against? More details please! Any pics or videos of the proedure?
August 03, 2011, 11:24:57 am
92EcoDiesel Jetta
August 03, 2011, 11:24:57 am »
OK I figured it out! The crucial thing is to support the screwdriver so it is not prying against the seal itself! I used a big box wrench.
Here's what my modified screwdriver looks like. A bit out of focus. A long screw driver helps with leverage. The one I used is about 12"
Cleaning up the shaft sealing surface before the new seal goes in.
Last Edit: August 04, 2011, 07:36:28 am by 92EcoDiesel Jetta
August 03, 2011, 08:27:12 pm
arb
August 03, 2011, 08:27:12 pm »
Are you using the Greesel compatible seal for your new one ?
August 04, 2011, 05:54:41 am
92EcoDiesel Jetta
August 04, 2011, 05:54:41 am »
You mean Viton? No they're BNR which should be ok.
