Author Topic: Deleting A/C  (Read 2056 times)
August 02, 2011, 06:24:54 am
Tom77
  • 16
Deleting A/C
« on: August 02, 2011, 06:24:54 am »
Do I have to remove the IP to delete the a/c on a 82 Rabbit?
Reply #1August 02, 2011, 06:33:27 am
Re: Deleting A/C
« Reply #1 on: August 02, 2011, 06:33:27 am »
I don't think so. I think all you would need to do is take off the a/c compressor and make sure you have a v belt and or v belt pulley lined up to drive the water pump. You could take all the lines, evap, condenser, and what not as well.
Reply #2August 02, 2011, 01:21:58 pm
Re: Deleting A/C
« Reply #2 on: August 02, 2011, 01:21:58 pm »
the water pump is gona be fine. its the alternator bracket or pulley that needs to be changed.
the alternator is going to be a mile off from the correct offset to drive it.. its too far in.
