Author Topic: Is this bad?  (Read 2390 times)
July 28, 2011, 07:37:29 pm
jaysen71581
  • 211
    Hagerstown, MD
Is this bad?
« on: July 28, 2011, 07:37:29 pm »
Yes i know its bad lol.. Im not having any luck sourcing this, also would this be the reason i had oil leaking out from the car?  And why would that crack like that??
Reply #1July 28, 2011, 08:11:37 pm
Re: Is this bad?
« Reply #1 on: July 28, 2011, 08:11:37 pm »
Bad install is my guess.
Purdy sure this one will fit (but check first)
http://www.germanautoparts.com/Volkswagen/Jetta/Engine/65/4
Reply #2August 01, 2011, 01:54:53 pm
Re: Is this bad?
« Reply #2 on: August 01, 2011, 01:54:53 pm »
I think I've seen them for sale an different online stores so you shouldn't have to hard a time finding one.
http://frugalmechanic.com/auto-part/goetze-w01331626754-crankshaft-seal
Hope this helps.
Reply #3August 01, 2011, 02:58:12 pm
Re: Is this bad?
« Reply #3 on: August 01, 2011, 02:58:12 pm »
you can buy the seal pressed into the retainer from TT, and from other places..
Reply #4August 01, 2011, 05:13:46 pm
vanagonturbo
  • 639
    • Fine Tuning
Re: Is this bad?
« Reply #4 on: August 01, 2011, 05:13:46 pm »
This is the best solution. A PTFE seal is far superior to the standard rubber/spring seal. There is one problem though, the two bolts that go into it through the oil pan are 7mm vs the original which are 6mm. So you will need to drill the oil pan out a little bit to accomodate the larger bolts. I have this seal on my Scirocco and I dont suspect to see it leak for a very long time.
Reply #5August 01, 2011, 08:31:09 pm
Powered by Spearco
  • 1203
Re: Is this bad?
« Reply #5 on: August 01, 2011, 08:31:09 pm »
Just get the PTFE rear main seal for the VR6 and press it in to the orginal Rabbit seal carrier.
Or get the combo seal w/PTFE seal with the 6mm holes.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
