Author Topic: Which head gasket and bolts?  (Read 5083 times)
Reply #15July 27, 2011, 06:02:04 am
92EcoDiesel Jetta
Re: Which head gasket and bolts?
« Reply #15 on: July 27, 2011, 06:02:04 am »
Wow you are lucky! Is that why you burn your money? ;D
I am noticing rust in the block coolant passages from the high amount of water I added. What's the best way to get rid of the rust before filling with G12?
Reply #16July 27, 2011, 07:06:27 am
« Reply #16 on: July 27, 2011, 07:06:27 am »
Once I had everything back together I filled it up with water and then used one of those rad flush things and just keep flushing until it came out clean.
Reply #17July 27, 2011, 04:14:28 pm
92EcoDiesel Jetta
« Reply #17 on: July 27, 2011, 04:14:28 pm »
Good news! Head pressure tested good- no leaks. Gotta order parts and put it back together. I have a set of valve stem seals. Should I put them in and lap the valves? The shop vacuum tested the valves and said it held 28" of hg, so the valves are sealing well.
